Help Setting Lifters on 305
I dont know if i have set the lifters right on my car.
The block and heads are stock.....89 RS Camaro TBI. I have rebuilt the engine.
When i set the lifters I rolled the engine to the proper place, then tightened half and rolled the engine again to tighten the second half.
The intake was off when I did this so i was careful not to compress any lifters.
After intake was mounted and a lucky guess on timing the car fired first try.
With the engine running I carefully tightened each lifter until it just stopped chattering and then gave them a 1/4 turn...and so on with each lifter.
Was that ok to do on the 305?
Re: Help Setting Lifters on 305
Its a preference and application thing. On a nearly stock to mild engine, most people go 1/2 turn past zero (point of no clicking). Personally, on a mild (little more than stock) I like to go 1/4 turn. They are hydrolic lifters though, so if you go 1/4 on some 1/2 on others and even 3/4 on some other ones, you will not notice a different. At least not on the level of engine we are speaking of.
Transmission: 4L80E/4L80E
No, a high volume pump doesn't change anything.
One full turn down from zero is the proper adjustment. I've done the 1/4 or 1/2 turn thing for years, heard it would help the engine rev higher but valve train was always noisy. Finally did 1 full turn down on the Camaro last year - viola, runs great and no lifter noise.
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
My 97 LT1 runs much weaker with the lash set loose,like just enough to make it quiet. 3/4 preload and it runs much better. I tested that theory with timeslips.
Most service manuals recommend 3/4 turn. The cam installed wont matter since the adjustment is done with the lifter on the base circle of the cam and it needs the correct preload.
They need to be tightened down till they arent noisy, as five7 said. I have always been able to get away with 1/4 to 1/2 turn and not have noisy valvetrain on my SBCs.
You can tighten them to zero lash and 1/8th turn past and they will be quiet. Thats where I had my 97 adjusted to and it would only run a 14.10 at best. This was after several runs to. Once set to 3/4 turn it ran a 13.62. I never would have thought it either. I suppose it's something like solid lifter cam in that a few thousanths can alter the power some. Maybe the air was cooler on the quicker run but the car felt stronger to so I know it makes a differance. Now,on a lower hp 305 it may not be as drastic of a change but I always go 3/4 turn past 0 lash on a SBC hydraulic cam. The only exception would be if a cam company advised otherwise.
To be honest, and I am not trying to sound like a jerk, you didnt gain .5 second by tightening your rockers up a 1/2 turn. On a solid lifter cam a few thousands cam take the cam out. The difference is that on a solid cam if you were running a few thousands looser you would be losing some lift because of it. On a hydrolic cam when you hear no noise you have hit the point of zero lash, and any past that you are going to realise the full lift of the cam.
You dont come across like a jerk at all. I dont think that was all of it either. I'm thinking it was a cooler day for the quicker runs and I may have gotten a better launch,who knows. But what I am saying is that it did help some and I could physically tell the car ran better. So I always set mine to 3/4 after 0 lash.
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Really it's not going to make to much difference although I wouldn't go less then 1/2 myself.
If you measure it out you will find that 1 full turn is .050 and that will center it in the lifter (hydraulic is what im talking about)
Now thats neat to know. I have used the Chilton's and Haynes manuals and they say 3/4. I'd rather go by a GM manual though.
Car: 1988 C1500
Engine: L05
Axle/Gears: 3.73 open 10 bolt
If you go too tight wouldn't that increase parasitic drag (albeit slightly) and also wouldn't it not allow the valve to fully close? Or are we talking like 2-3 turns for that to happen? I've always set mine at 3/8-1/2 for that very reason but this thread has me thinking that if the weak hydraulic lifter gives at all being set that loose I won't realize full cam lift (all .350" of it
). Supreme Member
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
).I had a '79 elcamino, the guy who had it before me had half of the lifters really tight, prob 3-4 turns past 0! and the other half really loose(clacking away!) with no preference towards intake or exhaust. they were all very different. it was ran noticeably better when I readjusted the valves!
The theory from days of yore was the lifters would "pump up" during high RPM operation and cause the valves to not fully close. If you only turned them down 1/4 to 1/2 turn and the lifters "pumped up", the valves wouldn't be held open as much. That may have been the case 50 years ago with hydraulic lifters, but it certainly isn't the case anymore.
colton_carlson
Mar 8, 2019 12:21 PM
Fast355
Dec 2, 2016 06:33 PM
ambainb
Apr 25, 2016 09:21 PM
