Heads !!!
Heads !!!
I need a list of heads that were used on the 89 RS Camaro..305 TBI.
Ive been browsing the web but had no such luck.
I thank you for your help.
Transmission: 4L80E/4L80E
There were two - left and right.
The casting # ends in 191. Swirlports.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Heads !!!
Correct, only one casting used on those engines from '88-92. The same casting for left and right sides, they are interchangeable from side to side (just to avoid any confusion by Five7's clever line
) Member
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: Heads !!!
https://www.thirdgen.org/forums/tech...light=14102191
This thread I did a while back. YES the 191 head ARE 76cc combustion chambers. It is what was on my reman 350 from Advance Auto. I did online research and spoke with numerous machinists/engine builders. ALL say 76cc combustion chambers.
Yes, I did measure them with a burett and yes they are 76cc, lol.
You will find a number of guys on here telling you that they are 64cc or something different. Well, my 14102191 heads are/were 76cc. My compression was just right around 9.5:1.
Hope this helps.
Hope this helps.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
