Grinding noise identification
Old Jan 4, 2009 | 04:30 PM
blindslide's Avatar
Car: 1984 camaro z28
Engine: LG4
Axle/Gears: stock
first post to the boards,
hi everyone.
I own a 1984 z28 (auto with 5L - non/ho)
Family owned since it rolled off the lot,
It was stolen about 3 years back,
and was garage kept since then...
I recently got it running again,
new everything minus a rebuild,
but heres to my question,
when it was stolen they used a screw driver to turn it over,
and now when i turn the key to on,
it makes a ticking noise like the starter is trying to turn over,
is the ticking normal or no?
(when i turn the car over, the starter works, only when in the ON position it makes the ticking that i can hear)
also when i get on the gas,
in first gear aboce 2.5 rpms it makes a grinding kinda noise until it shifts
but shifts clean,
goes through all the gears...
could it be the starter engaging when i get on it?
or is it a tranny problem?
all help is much appreciating.
Old Jan 4, 2009 | 07:14 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Grinding noise identification
How/where did they use the screwdriver? In the ignition on the steering column?
Old Jan 5, 2009 | 06:16 AM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
im guessing the ignition where you put the key in.
but again, im not sure.
it may have messed up something in the steering column,
because for a while i had to use the tilt wheel and move the wheel up and down til it would turn over...
but then i found the sweet spot and i dont have to move the wheel now.
Old Jan 5, 2009 | 07:48 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
they probably stole the car to beat it like a red headed step child
get more indepth in the grinding noise and try to narrow it down
Old Jan 5, 2009 | 07:58 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
If the steering column was damaged when they stole it, I'd first look at the ignition swich which is located down near the bottom of the column.
Old Jan 5, 2009 | 08:28 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Does the starter engage wile the key is in the run position before turning the key all the way to the start position? Or is the starter just staying engaged when the key returns to the run position after starting it?
If it is the first situation then there is something messed up with the wiring, steering column, or ignition switch.
If it is the second situation then more then likely the starter solenoid is just not disengaging. Could still be something with the ignition switch or steering column though.
Old Jan 5, 2009 | 04:17 PM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
replaced the starter .... it only makes the ticking when in the on position, and fully turns over when turned to start position... when turned off = no noise. all i hear is a ticking so i assume its the starter trying to turn, but not getting quite enough juice to do the job until you turn it all the way over.
Old Jan 5, 2009 | 05:10 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
When in the ON osition, there should be no power to the starter per se.
Only when the key is turned to the START position do things happen at the starter. 1) The solenoid gets power and pulls the starter drive gear to the flywheel, 2) The solenoid moves a contact within that completes the circuit from the battery to the starter motor and the starter motor spins.
If the clicking you hear is indeed coming from the starter when the key is in the ON position, then this is not right. My thinking is when your car was stolen, the thieves buggered the ignition switch.
BTW, when in the ON position and the engine OFF, do you hear constant clicking or ?
Old Jan 5, 2009 | 05:38 PM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
The ticking you hear when the key is in the ON position is the mixture control solenoid in the carburetor. Its always ticking, you just can hear it well when the engine is running.
Old Jan 5, 2009 | 06:01 PM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
1) when car is off and key is out, no ticking noise.
only when power is on and car is not running can i hear the tick**
2)I guess they jacked up the column pretty bad,
i called my grandma to confirm what had happened.
3)Could it be the starter engaging when i am full throttle to cause the grinding?
4) heading out today to get the parts for the column to maybe solve the ticking and hopefully the grinding all at once...
Old Jan 6, 2009 | 12:17 AM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
new info as for the grinding noise,
sounds like a screwdriver scrapering metal,
but really fast,
coming from just behind the engine,
i can feel it really well with my pedal foot.
Old Jan 6, 2009 | 12:23 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Check the torque converter cover "its a black plastic bell looking thing that keeps the dirt outa the TC and starter.
Make sure its in good shape and not cracked and getting ground upon by the TC.
Maybe some TC bolts have come loose.
A sound clip or video with sound could help out a lot in this diagnosis.
Old Jan 6, 2009 | 08:34 AM
jamon8's Avatar
Engine: 350 tpi
jroughs on the right track
take that cover off and have someone turn the key, start it and leave it running
dont worry it wont bite
report what you see or fix it if you can
Old Jan 6, 2009 | 01:02 PM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
well,
to get a sound clip of the noise,
id have to be in gear and driving,
i will see if my brother can help me with that...
i got rid of the ticking by replacing the ignition in the column,
but still makes a bad scraping noise,
ill check the TC cover today and get back to you all.
Old Jan 8, 2009 | 12:18 AM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
i found whats looks like a a counterweight for the flywheel...
how do i get the flywheel out to re balance it?
Old Jan 8, 2009 | 06:32 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
You have to separate the engine and transmission to the flywheel (flex plate) out.
Forget re-balancing. Just get a new flex plate.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
hdis2002
Sep 8, 2015 02:52 PM
Randomtask2
Sep 7, 2015 05:06 PM
