350 tpi rebuild
Old Jan 8, 2009 | 06:35 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
350 tpi rebuild
Hi this is my first time rebuilding an engine and it is all stock i just want to know if this is all i would need i am just making a basic rebuild http://cgi.ebay.com/ebaymotors/1986-...Q5fAccessories
and this rings http://cgi.ebay.com/ebaymotors/1986-...Q5fAccessories
Old Jan 8, 2009 | 06:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 tpi rebuild
You need bearings too, but you won't know what size until you've seen what shape the crank is in.
Old Jan 8, 2009 | 06:50 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 350 tpi rebuild
Would they tell me that in a the shop because they are cleaning it right now
Old Jan 8, 2009 | 06:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 tpi rebuild
Most likely they'll tell you if it needs any machining.
Old Jan 8, 2009 | 06:58 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 350 tpi rebuild
He already told me it doesn't need any machining but do i need to change the bearings
Old Jan 8, 2009 | 07:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 tpi rebuild
It's not really a rebuild if you're not changing the bearings.
Old Jan 8, 2009 | 07:08 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 350 tpi rebuild
Which are does can you tell me which ones
Old Jan 8, 2009 | 07:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 tpi rebuild
There's only 3 sets, the main bearings, the cam bearings and the rod bearings. The cam bearings need an installation tool to put in, you can ask the shop to do it for you, though.
Old Jan 8, 2009 | 07:15 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 350 tpi rebuild
Like this one http://cgi.ebay.com/ebaymotors/1986-...Q5fAccessories
would be good they told me it has a performanace cam but i just bought the engine a month ago for $500 with all the accessories
Old Jan 8, 2009 | 07:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 tpi rebuild
All your links are to the same gasket kit.
Old Jan 8, 2009 | 07:23 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 350 tpi rebuild
My bad i meant to put this ones http://cgi.ebay.com/ebaymotors/Main-...Q5fAccessories
Old Jan 8, 2009 | 07:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 tpi rebuild
No, those are Oldsmobile bearings.
Old Jan 8, 2009 | 07:36 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 350 tpi rebuild
which ones then send me a website were i can find them
Old Jan 8, 2009 | 07:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 tpi rebuild
Assuming everything is stock size and the crank isn't turned at all:
Mains:
http://store.summitracing.com/partde...M&autoview=sku
Rods:
http://store.summitracing.com/partde...P&autoview=sku
Cam:
Old Jan 8, 2009 | 07:49 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 350 tpi rebuild
So with those and with the kit i showed you that would be good stock rebuild right
Old Jan 8, 2009 | 08:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 tpi rebuild
Pretty much, plus rings.
Old Jan 8, 2009 | 08:06 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 350 tpi rebuild
Thank you i will tell you when i finish rebuilding the engine can i add you my friends
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
