code 34 to code 33
Old Jan 10, 2009 | 03:26 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
code 34 to code 33
87 gta, 350, had code 34 , i replaced maf, now i have a code 33, after i changed maf, the car idle ruff, then smoothed out (all while ses light was on) then light went off for a few seconds, car sounded terrible then light came back on and started idling fine, any suggestions, thanks in advance
Old Jan 10, 2009 | 04:03 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: code 34 to code 33
wat are the codes again? i think i threw a 34 code once. it was the maf burnoff fault. i replaced the MAF with an extra i had and replaced the MAF burnoff relay and if took the check engine light off. my car wasnt running rough tho. the relay is cheap and is in the cluster of replays where the fuel pump relay etc is on the driver side firewall.... well on my firebird it is. could be that relay
Old Jan 10, 2009 | 04:44 PM
TOM305T/A's Avatar
maybe i will put old maf on and change relay and see what happens
Old Jan 10, 2009 | 05:27 PM
Car: 87 TA clone
wat is code 34 by the way?
Old Jan 10, 2009 | 06:24 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
there are 2 relays for maf burnoff and a power one replace both first
Old Jan 12, 2009 | 07:52 AM
TOM305T/A's Avatar
The maf burnoff and power relay or the 2 relays to the far right of the brake booster correct. i will pick those up today, they should be the same relay correct
Old Jan 12, 2009 | 06:12 PM
TOM305T/A's Avatar
I changed both relays, still has code 33, and car still wont start (without giving it gas)
Old Jan 12, 2009 | 07:50 PM
Vader's Avatar
33-MAF sensor indicated an air flow of 45 gm/sec or more for 0.600 second when TPS was less than 1/4 throttle and engine speed was under 2000 RPM.
34-MAF sensor indicated an air flow of 25 gm/sec or less for 0.600 second when TPS was above 6% and engine speed was above 2300 RPM.
I'd say it's time to check the MAF connectors, MAF relay connectors, and TPS voltage.
You might also want to check the throttle body for leakage and the PCV system, especially verifying the valve is correct.
Old Jan 12, 2009 | 09:37 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Also, do a search, there has been more stuff written on this topic than any other, I believe.
Old Jan 13, 2009 | 02:51 AM
Car: 87 TA clone
not starting without giving it gas?... hmmm... the code is something withe the maf or tps as Vader stated. do what he said, but the giving it gas... maybe u should also check fuel pressure. its an 87 so u have a cold start injector, that would give u hard starts. i would check your IAC as well as TPS. just go through everything
Old Jan 13, 2009 | 01:18 PM
TOM305T/A's Avatar
i will try to work on it when i get home, but the not starting/running without giving it gas started right after i changed the maf
Old Mar 30, 2009 | 08:44 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
im having a simalar problem right now
Old Sep 9, 2009 | 04:03 PM
larrywHawaii's Avatar
Car: 89 firebird
Engine: 2.8
Transmission: automatic
According to my book code 34vacuum sensorcircuit It says Check wiring to terminals 20,21 and 22 of the ECM Check the connections at the ECM. Check the vacuum sensorwiring and connections.*Replace vacuum sensor(located in the engine compartment)
Old Sep 14, 2009 | 06:35 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Old Sep 15, 2009 | 12:25 PM
irish887j's Avatar
First things first....code 33 and 34 can be a tricky without proper diagnoses...Find the chart that guides you in probing the MAF harness to ensure proper function of the system in general...this will allow you to find out if it is in fact the MAF sensor, MAF burnoff relay, or a problem with the circuitry....once this problem is elminated move on to adjust minimum air adjustment, once this is properly set you will then need to correctly adjust your TPS sensor to obtain proper volatage....once all these have been done in order you should be in the right boat hopefully spending the least amount of money needed to get yah up and runnin....it sounds like alot but its really not
Old Oct 8, 2009 | 10:20 PM
dirtyd6669's Avatar
Car: 87 Trans Am
To irish887j i am having the same problems as these people and i read ur quote and i was wondering if the haynes manual will help me find all of these problems so i can try and fix them or if i need to get something else
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
