windage tray
Old Jan 12, 2009 | 08:07 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
windage tray
do they make one for the l98 f-body engines.... can someone give me a link to one that will work with a stock oil pan..... thanks.....
Old Jan 13, 2009 | 09:56 AM
88fastgta's Avatar
Re: windage tray
im just tryna figure out weather our stock pans have a windage tray and if so do i need special main cap bolts for my 4 bolt main to use my old l98 tray... if our cars didnt come with a windage tray then im not gonna bother getting one because my car ran fine..... if not could i use these main cap bolts for my 4 bolt block
http://store.summitracing.com/partd...32&autoview=sku
Old Jan 13, 2009 | 10:05 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: windage tray
AFAIK the fbodies didn't come with windage trays - don't know for sure about the vettes.
The oil pan comes with internal baffles.
I use a Moroso windage screen. It comes with ARP studs for the mains. I had to remove the baffles in the pan to run the screen. It also required some slight bending in a couple of spots since it isn't designed to fit any specific factory oil pan.
If you're not going to use a tray or screen then I see no reason why those main bolts wouldn't work with your caps.
Old Jan 14, 2009 | 03:31 PM
David 91RS/Z28's Avatar
Re: windage tray
My block is still a 2-bolt, and I used a windage tray from an LT1. I don't recall any of the TPI engines having factory windage trays...at least on the F-body's.
Old Jan 14, 2009 | 06:45 PM
Rob D's Avatar
Re: windage tray
Not sure if it would work or not but the L31 vortecs came with a factory setup that uses 3 studs for the crank bolts. You might try to find one of those at your local wrecking yard. I wouldn't think there would be that much difference in the two engines.
Old Jan 15, 2009 | 07:16 AM
88fastgta's Avatar
Re: windage tray
well i already have a 93 4 bolt main that has three studs while the others are just bolts... it looks like it had a factory tray but im not sure.... could i just buy a tray on ebay and bolt it on the three studs and use my l98 oilpan.......
Old Jan 16, 2009 | 08:08 PM
Rob D's Avatar
Re: windage tray
Well I'm thinking you could....but just to be sure I think I'd measure the dimensions between the studs, or make a cardboard pattern of them and head out to the wrecking yard to see if I could find one there. It would probably be less $ anyway. Even if all you found was a junk one you could at least verify the pattern so you could have the egay seller verify that. BTW mine does fit in the factory pan.
BDR
Nov 7, 2015 03:05 PM
customblackbird
Oct 1, 2015 04:30 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
RW91B4C
Jul 17, 2001 08:53 PM
