91 RS 305 TBI unable to start
Old Jan 13, 2009 | 10:51 AM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
I bought my vert with a L05 that had overheated and needed a rebuild so I swapped in a lo3 that came out of another 91 RS. I finally completed the engine swap, I also did a t5 swap and bipassed the neutral safety switch so that isn't the issue. At first I tried starting the car and the motor turned over but did not start. We sprayed starter fluid in the tbi unit but it kind of wanted to start then back fired. I then realized that my electronics were not working and fuses were not getting any power. I found that a bad ground was causing this since it was installed on the alternator bracket. I checked on my 89 parts car and i saw that they are getting ground from the passenger side of the block. After messing with the ground the electronics began to work again and my pump is priming but I still cannot start the car. I thought I may have a VATS issue but vats prevents starter from receiving power right? if so thats not the case.
Any ideas?
Old Jan 13, 2009 | 11:17 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 91 RS 305 TBI unable to start
Have you checked the control module in the distributor?
Old Jan 13, 2009 | 11:19 AM
z28gsxr's Avatar
Engine: 5.7/5.0
no i have not but I will look into it once i get home today. I spoke to my friend which was helping me out and he said he recalls that the security light was on. So it may be a VATS issue. I am going to look into over-riding VATS. There is spark. I know this because it backfired while trying to start and it caused a small fire which was quickly put out
Old Jan 13, 2009 | 05:22 PM
z28gsxr's Avatar
Engine: 5.7/5.0
anyone? does this sound like a vats issue?
Old Jan 13, 2009 | 07:15 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Back firing indicates that your timing is off. Pull #1 cylinder plug and rotate engine with a breaker bar until balancer indicates 0 TDC and you can feel #1 cyl piston with a straw. Mark #1 cylinder position on dizzy body then pull dizzy hat and see if rotor is aligned against this mark. This should get you close enough to get her started.
//RF
Old Jan 13, 2009 | 11:25 PM
z28gsxr's Avatar
Engine: 5.7/5.0
Thanx for the help that was it. Distributor was almost 180 off of where it should be pointing. But now the issue that I'm having is car is running extremely rich and does not have a service light on. Any ideas on what is causing it to run in this manner.
Old Jan 13, 2009 | 11:37 PM
RFmaster's Avatar
Car: 75 Beast
OK, do you have 5.7L TB on top of your 5.0 (LO3)??? If so the chances are that 5.7 L injectors are dumping too much fuel... Another possibility is defective CTS - but that will result in SES...
//RF
Old Jan 13, 2009 | 11:58 PM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
The distributor was on the exhaust stroke. Ive seen that one before.
You can stick your finger in the #1 spark plug hole to feel the compression stroke too since both valves will be closed.
Good luck with your swap!
Old Jan 14, 2009 | 09:25 AM
z28gsxr's Avatar
Engine: 5.7/5.0
//RF
The 5.7 TB is possible because when I bought the car it had an L05 in there. I have an 89 L03 parts car that ran when I parked it in my back yard. Should I remove the TB from that car and install on mine?
Old Jan 14, 2009 | 09:38 AM
RFmaster's Avatar
Car: 75 Beast
Take a look at injector tops - they should have color markings and part numbers:
Green/White 5.0L 40 lb/hr GM 5235279 *RPD
Orange/Black 5.7L 55 lb/hr GM 5235206 *RPD
Color markings may get rubbed off, but part numbers should be there, and maybe difficult to see. Post what you find, but the chances are you'll need LO3 injectors to stop immediate flooding condition.
//RF
Old Jan 14, 2009 | 09:43 AM
z28gsxr's Avatar
Engine: 5.7/5.0
I have a set of injectors in the parts car. i will take a look once i get home from work
Old Jan 15, 2009 | 10:22 AM
z28gsxr's Avatar
Engine: 5.7/5.0
I swapped in the ecm from my 89 parts car. Its also a 5spd l03 and it idled better. I put fluid in the trans then started it up and went to put it in gear and it wouldn't go in. Completely forgot about bleeding my clutch hydrolics
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
