Toggle Switch
Car: 92 RS Camaro - 25th Anniversary
Engine: 3.1 V6
Transmission: I dont know. Its an automatic! LOL
Axle/Gears: Dont know, but has CENTERLINE RIMS!
Toggle Switch
help
Hi. I need instructions to make a toggle switch for the fan relay. Fan only comes on when i use a jumper wire in the relay. So, everytime i go somewhere, i have to pop the hood, insert the jumper wire, & then pop the hood, and take out the jumper wire when i get there. i have traced the relay wires as far as i can see and reach, and checked the wires with a test light. fuse is good. replaced the relay from a "pick&pull" car graveyard. just want to do a toggle switch now. This is what i need to know:
the starting point for the wires, where to route them, & connect them
*o~o*kimberley*o~o* Junior Member
Car: 2003 SILVERADO /86 IROC/85 S10
Re: Toggle Switch
The hot wire tothe fan, after the relay, is where to put the toggle switch. Run the hot to the "off" side of the switch and then run a new wire from the "on" side to the fan.
Engine: 3.1 V6
Re: Toggle Switch
thank you for replying. i have never toggled before so i just want to be certain cuz im a little nervous. but not afraid. the red wire is the one that lights up w/o the car on. this would be the hot? (know your laughing)
kimberley
kimberley
Transmission: 4L80E/4L80E
The relay is there because the fan draws more current than you want to put through a switch.
The large red wire you're speaking of always has power. The normal fan switch energizes the relay by grounding the relay magnetic circuit, the other small wires on the relay. One of those wires should get power when you turn on the ignition - the other one is grounded to complete the circuit and close the relay contacts, putting power to the fan.
It would be best to use your toggle switch to energize the relay, rather than power the fan directly.
Engine: 3.1 V6
Re: Toggle Switch
thank you. i understand what your saying. i will let you know how it turns out. will write on saturday night.
kimberley
kimberley
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Toggle Switch
The wire you need to toggle is the one that the ECM controls unless the ECM fan driver (drives it to ground) is faulty you should trace the wire to find the disconnect and repair it, or not, just my 2 cents.
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: Toggle Switch
I agree with tracing the wires properly.
Lots of power needed for the fan.
If a toggle is The only option, At least toggle it across a higher power relay.
This would ensure that you do not have the chance of an electrical fire somewhere.
If you need a diagram for this I'd be happy to oblige.
All you would need is a 4 pin relay and a toggle switch.
I'd definitely go that way rather than just a bare switch.
However it comes to mind that if you're jumping across the relay then the relay you have may be bad.
EDIT: find attached a quick diagram of what you need if you must use a toggle.
Finding the fault would be the best bet though.
Engine: 3.1 V6
Re: Toggle Switch
thank you. i put in a toggle that powers the relay and not the fan directly. i am happy with how it is performing. thank you for your help.
Kimberley
okay, the toggle switch is installed, and working well. and im glad it is mentioned that the fault needs to be found in the wiring. i totally agree. ignoring it and going past it works, but its not the right long term solution. i hate half assed measures. okay, on my relay, the brown is the fan fuse, green/white is the ECM, and then the red & red/black. the ECM is where i think a fault lies too since i can jump the relay, and now toggle the relay.
what should i do to find the fault?
Kimberley
Last edited by 3colored 92 RS; Jan 18, 2009 at 10:40 PM. Reason: Automerged Doublepost
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: Toggle Switch
Well what you've actually done is the job of the ECM.
The fault most probably lies within the ecm.
I do not have a schematic for it at the moment but I'd like 1 just to have and study it.
Posibly just a blown diode inside or a dry solder joint or maybe even a burnt portion of the board itself.
It's hard to say really. Are the temperature sender/switches good?
If the ecm does not get the right info, it cannot react accordingly.
Glad you fixed up temporary though. It's a semi permanent fix though too. As long as the relay control wire is shielded. You did tape it up right?
Car: 88' IROCZ
Axle/Gears: 2.77
Re: Toggle Switch
Kimberley
Kimberley
- Did you use the existing relay and connector
- New relay on existing connector
- New relay and connector
- Did you cut the wires, or splice on to them?
Randomtask2
Sep 10, 2015 08:37 AM
