What would you recommend me to get?
Old Jan 16, 2009 | 03:13 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Ok I have set a list of what I want to get done to my car this year.
Headers.
Throttle Body.
Cold air intake.
Rear end gears.
Camshaft.
I know all of you will say get hooker headers but im going with headman. Throttle body im looking into BBK and cold air is SLP if I can find where to get them. Rear end gears im looking into 3:73 to 3:90. Camshaft I have no idea what to look at. Do you guys recommend anything diffrent. Please dont say hooker headers, I heard the story many times already haha.
I also might not be able to afford all the upgrades since I do have to remove some minor rust and get two of my rims repainted. I have enough or am close enough for the performance parts but not the cosmetics
Old Jan 16, 2009 | 03:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What would you recommend me to get?
I wouldn't bother with the throttle body.
Old Jan 16, 2009 | 11:03 PM
Transmission: 700r
can I ask why?
Old Jan 16, 2009 | 11:06 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
If your engine is stock other than the things you're going to be doing to it, then the TB doesn't really cause enough of an obstruction to limit power right now. It's not your limiting factor yet.
Old Jan 16, 2009 | 11:10 PM
rezinn's Avatar
Originally Posted by 87IROCZCamro
can I ask why?
Waste of money since the minimal mods you're going to do will not require a larger throttle body.
You can fabricate your own "ram air" style cold air intake with your stock air box connecting to behind the fog lights.
Don't overlook things like subframe connectors, strut tower brace, and suspension goodies. These can be pretty cheap and make the car feel a lot tighter and handle better.
Old Jan 17, 2009 | 11:14 AM
danandamy's Avatar
Car: 86 Camaro
I'm running the Hedmans and love 'em. Installation was pretty easy too. Go with something like a Lunati 00017 http://store.summitracing.com/partde...7&autoview=sku. If you go with too much lift you will have to change the valve springs. I've run this cam for years and it works well and I never changed the valve springs. Good luck and have fun with it. Half the fun is trying out different combos that you decide on and see how they do. Dan
Old Jan 17, 2009 | 04:41 PM
Transmission: 700r
How much horsepower did you gain?
Old Jan 17, 2009 | 05:19 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
I would say that the most bang for the buck by itself would have to be the gears, the 3.73 will really help your acceleration, or tire smoke tremendoulsy if you have 2,73 or similar now, then I would work on the headers, so thet when you install the cam later you will be able to support it. I agree that a set of 2210s would be way to much for your car and not money well spent, I would probably buy a set of shorties to keep ground clearance, just make sure you get 1-5/8 primaries. With your combo I would not get carried away with suspension mods, I have an 11 second camaro with stock suspension, when I went to subframe connectors I could tell no difference, now don't get me wrong, they are a good idea for a unibody car, but you will not get any more fun out of the car with them in my opinion, I would say the same for a strut tower brace ect.They will help your car handle better, but I have always thought these cars handle great, I just wanted mine to go fast along with that handling.
Old Jan 17, 2009 | 10:48 PM
Transmission: 700r
I agree with you. The handling on these cars to me a great and Im not road racing so its not a concern right now. I have enough money for the camshaft,headers and gears. Im hoping the car will run low 14's maybe.
Old Jan 18, 2009 | 10:53 AM
bart91406's Avatar
Car: 91 rs
Transmission: th350
That would be a perfect way to go about it, the camshaft headers and gears will greatly increase your performance for not to much cash. good luck and have fun with your build.
Old Jan 19, 2009 | 12:04 AM
Transmission: 700r
What good cam would go into a stock 350 without changing everything else?
Old Jan 19, 2009 | 12:20 AM
bart91406's Avatar
Car: 91 rs
Transmission: th350
Well that is a question you may get a whole lot of different answers to! I do think many people agree the Lunati Voodoo line of cams are excellent performers, and are priced right. It is the size of the cam that is up for debate. Personally, I would reccomend something with a 252-262 advertised duration. I am not sure however how much cam you can run with stock valvesprings, I would imagine something in that size would work, but maybe someone who has tried it will chime in and let you know what worked for them.
Old Jan 19, 2009 | 10:43 AM
Transmission: 700r
someone said there running 290 and that he hasn't had too redo everything
Old Jan 19, 2009 | 10:50 AM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
I've heard .420" was max lift for stock valve springs, springs wont run you to much more and will prevent you from running into any problems in the future with the valvetrain, like coil bind, so I would atleast replace the springs with the cam.
Old Jan 20, 2009 | 10:20 PM
Transmission: 700r
So what does everyone recommend for the cam?
Old Jan 20, 2009 | 10:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The problem's not the springs, it's the valveguide clearance. You need to machine the heads for more lift, but it's a trivial operation.
Old Jan 21, 2009 | 01:49 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Voodoo's aren't intended for EFI setups, unless you do some serious tuning. Which, nothing of the sort has been mentioned.
If the bosses are getting milled, then I would look to the Comp XFI line. Seen good results with those grinds.
Old Jan 21, 2009 | 02:51 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
hey guys i really dont mean to jump your thread, but i was wanting to do some similar things (cam, maybe valve springs, and gears) i alright have headers. how much does all this usually go for?? mainly the gears. id like a 3.73 or a 3.42 gear. what do these usually price for and what brand of gear would you suggest? and im with 87IROCZcamaro on the whole cam thing.. whats the biggest i can get WITHOUT changing valve springs and what not. i want biggest, but still safe so i dont have to worry bout somethin breaking.
sorry bout boosting your thread
Old Jan 22, 2009 | 09:25 PM
Transmission: 700r
Yea help us both out hahaha
F-body-fan
Jan 12, 2023 01:49 PM
Pac J
May 17, 2020 10:44 AM
drumstixer
Sep 29, 2015 03:02 PM
Zell1luk
Sep 29, 2015 10:36 AM
kitt23
Sep 26, 2015 07:48 PM
