how can i tell if i have air injection exhaust manifold???
Old Jan 21, 2009 | 08:02 AM
arozr600's Avatar
i was jw if someone could tell me by giving them my vin or help me out nd give me an idea what im looking for. The car is a 91 trans am GTA with 305 TPI. Im trying to by headers nd dont know wich ones i should get. I know i have an 02 sensor but have no idea what the air injection is. Any help would be greatt, thanks guys.
Old Jan 21, 2009 | 08:33 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: how can i tell if i have air injection exhaust manifold???
yes you need the air injection tubes to keep your air pump functional
are you having someone do the work for you or are you planning to do it yourself
Old Jan 21, 2009 | 08:50 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
You can easily tell air injection headers from non AIR headers. Look at the top of the headers where they bolt to the heads. If you see a smaller tube running across the top of all the exhaust tubes, they're AIR injected.
http://www.4wd.com/aux_incl/images.a...pg&w=200&h=200
Old Jan 21, 2009 | 08:56 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If the car is stock, you will have air injection on it. All models of 3rd gen cars have it as part of the emission controls..
Old Jan 21, 2009 | 09:22 PM
arozr600's Avatar
can i run the car without it? im looking to do a set of headers nd was wondering if im going to need it
Old Jan 21, 2009 | 10:22 PM
jamon8's Avatar
Engine: 350 tpi
I wish i did not buy the ones with air injection tubes
headers in the thirdgens on the pass side is hard enough
Old Jan 22, 2009 | 06:11 AM
DJP87Z28's Avatar
Just take the crap off, GM put it there so future AH's would have problems installing headers.
Old Jan 22, 2009 | 07:50 AM
arozr600's Avatar
lol alright cool thanks alot guys for the help
Old Jan 22, 2009 | 12:47 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
can i run the car without it? im looking to do a set of headers and was wondering if im going to need it
Please see the sticky post in the Exhaust forum "Can I run my engine without AIR tubes" and also the one about "What's the best exhaust? What are the best headers?" for help in choosing your headers.
The AIR tubes and AIR pump are part of the emissions devices for the car, and therefore it is illegal to remove them on a street car in all 50 states.
The Hooker 2055's are great for a stock engine.
No, GM put them there because it was required for the vehicles to pass the emissions test. They are required equipment per federal law.
Old Jan 22, 2009 | 01:44 PM
Stephen's Avatar
Car: 87 GTA
You can run without them, but your car will no longer pass inspections legally, in any of the 50 states.
AussiePr0nCar
Mar 6, 2020 04:04 PM
transaero
Aug 31, 2015 01:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
