Powermax 2032
Old Jan 24, 2009 | 04:34 PM
goleafsgo143's Avatar
Car: 86 Iroc-Z
Engine: L98 350 TPI
Transmission: 700R-4
Axle/Gears: 3.23 Posi
Powermax 2032
Can I install the crane cams powermax 2032 to a stock l98 without changing anything? I would be keeping stock heads, valves, valve springs, rockers etc. Thanks in advance for your help!
Old Jan 24, 2009 | 05:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You "can", but you really should at least change the valve springs. Springs and retainers would be even better.
Old Jan 24, 2009 | 06:45 PM
Car: 86 Iroc-Z
Engine: L98 350 TPI
Re: Powermax 2032
what kind of valve springs and retainers would you recommend for this set up?
Old Jan 24, 2009 | 08:08 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: Powermax 2032
http://store.summitracing.com/partde...5&autoview=sku
these are the springs that crane recommend when i used to run that 2032 on my heads..... comes with springs and retainers. these will work with stock heads and no machining is required...... much stronger than stock springs... and a 100 dollars thats not a bad deal at all.... thats pretty much all you need to run that cam... they recommend using a adjustable fuel regulator with this cam.. they claim that it will lean out the pistons or whatever.. so i bought the 60 afpr and bumped up the pressure....
http://www.youtube.com/watch?v=YmAOj...e=channel_page
hears what it sounded like in my car.... of course i have a ton of supporting mods when i ran the 2032 cam... a nice set of longtubes, y pipe and catback makes this cam very noticeable at idle...
Old Jan 24, 2009 | 08:22 PM
Car: 86 Iroc-Z
Engine: L98 350 TPI
Re: Powermax 2032
Thanks man , sounds mean ! So then I guess it means I have to take the heads off if I want to change the springs and retainers ?
Old Jan 24, 2009 | 08:29 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Powermax 2032
Heads don't have to come off to change springs. With the piston at TDC compression, just shove some nylon rope through the spark plug hole to pin the valves closed. Or use compressed air.
Old Jan 24, 2009 | 08:37 PM
Car: 86 Iroc-Z
Engine: L98 350 TPI
Re: Powermax 2032
cool.. another question though, not to sound stupid, but what would happen if I did run stock springs ? Could they handle the cam or would i run into problems? Appreciate the help.
Old Jan 24, 2009 | 08:44 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Re: Powermax 2032
Stock springs are garbage, at best. Extremely weak, and would not be able to adequately control the valve at upper RPM's.
Old Jan 24, 2009 | 08:54 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Powermax 2032
I'd say most likely stock springs would get valve float and possibly knock a valve with a piston. For the money and how easy it is, just go for new springs.
Old Jan 24, 2009 | 09:24 PM
88fastgta's Avatar
Re: Powermax 2032
yea i wouldnt trust 20 year old springs.... i would pay the extra 100 to assure nothing will happen... just a little insurance on your part... besides, that cam is the biggest you can go without doing machine work to heads or manditory computer work... the lift of that cam is about all the heads can take before running into trouble... so dont run 1.6 rockers with it...
Old Feb 18, 2009 | 10:45 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Re: Powermax 2032
Your car sounds mean 88fastgta,what other mods do you have besides the headers and exhaust? My wife got me the same cam and hooker shorties for valentines day. I have a HSR w/afpr, tpi airfoil, underdrive pullies. hooker cat back,ebay intake and a jet stage2 chip(not currently in), hoping for the same mean sound.
Old Feb 19, 2009 | 12:20 AM
88fastgta's Avatar
Re: Powermax 2032
thanks man.. i had alot of supporting mods... here are all the mods when that video was taken... the heated o2 sensor really made is sound like that, i dont know why but it sounded like a much bigger cam... i had everyone wanting to race me....
350 factory l98 engine
Rebuilt l98 heads
Cranes 2032 cam 452/465 214/220 112lsa
Cranes matching springs
SA performance double timing chain
Cranes Adjustable fuel regulator
Flowmasters 80s series 3.5 inch catback
Catco High Flow converter
Custom 3 inch built Y-pipe
Heated O2 sensor
Hedman Longtube Street headers
Ported and Siamesed SLP runners
Ported and Siamesed Plenum
Ported Edelbrock High flow Intake
SVO 24lb Injectors
SLP cold air intake with K&N air filter
SLP airfoil
IAT relocated to SLP air box
160 thermostat
Throttlebody Bypass
EGR delete
Heater valve delete
Air/smog delete
LT1 Starter
Heavy duty flywheel
MSD 8.5 super conductor wires
Accel super coil
Performance radiator
Pro built 700r4
Transgo shift kit
Tranny cooler
2300 converter
High flow water Pump
that was my old build... im using a 355 4 bolt main with a forged crank and rods with hyper pistons... im using the gm hotcam this time around... should be up and running within a few short months....
Old Feb 19, 2009 | 12:32 AM
bgood71's Avatar
Car: 89 GTA
Re: Powermax 2032
A lot of mods, but the 1 that really caught my eye was the heated O2. Whats the benefit and what O2 did you use and how is it wired? I hope my GTA sounds half that nasty.
Old Sep 11, 2021 | 09:14 PM
silverstang84's Avatar
Car: 88 IROC
Re: Powermax 2032
Reviving an old thread.. but I’m trying to locate the correct springs to install my 6492 (2032) cam.
Old Sep 11, 2021 | 09:23 PM
Re: Powermax 2032
There's no "correct" in the sense that anything else would be "incorrect". It's a pretty forgiving application with a wide variety of choices that meet the needs.
Practically any entry-level "performance" springs will work. The old "Z28" springs, Comp 981, the ones Crane suggest for that cam, Howards, etc. One of the best options nowadays is the LS6 springs and the Comp "adapter" retainers 787.
Old Sep 11, 2021 | 09:28 PM
Car: 88 IROC
Re: Powermax 2032
yeah I meant to say what springs would “match” the cam best. I know some people run stock springs, and I wouldn’t mind doing that to keep things as budget friendly as possible, but I do want it to run right. I’ll look into the options you listed. Thank you.
Old Sep 11, 2021 | 10:41 PM
Re: Powermax 2032
Stock springs do not "match" ANY cam. Not really even stock ones. They're the bare absolute minimum to get through the warranty period. Anything beyond that, is gravy.
By all means check all those out, there are others as well. I cannot emphasize strongly enough that in 2021 the LS6 ones are likely to be the best choice. After all, in the last ... however many years since the small block Chevy was introduced, in 1955 ... we've learned a thing or 2, as a species, about how to do this better. Take advantage of the learning. Not that it's "necessary", or any such; just, take advantage.
Old Sep 11, 2021 | 11:13 PM
vorteciroc's Avatar
Top Answer: 1
Re: Powermax 2032
Well said my Friend.
my90bird
Feb 14, 2009 05:59 PM
TKO500
Jan 5, 2005 09:38 PM
l98ta
Nov 4, 2003 01:01 PM
89FRMLA350
May 15, 2003 05:34 PM
89ROC
Apr 8, 2002 02:39 PM
