roller tip rocker arms... roller cam? cast #'s inside
Old Jan 27, 2009 | 04:11 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
roller tip rockers, roller cam? looking for valve lash spec for solid lifters.
i took the valve covers off today and saw that the rockers are roller tipped i cannot identify them though.
the head casting number is 462624.
from mortec...
462624.....75-86...350/400......76cc chamber, 1.72/1.5, 1.94/1.5 or 2.02/1.6 valves
the block's casting number is 3970014
3970014....350...70-76...2 or 4 (bolt main)
they are stamped rockers and after measuring appear to be 1.5:1 (i will post pics later.
would the roller tipped rocker indicate that i the motor has a roller cam and roller lifters?
is there an easy way to tell if the lifters are hydrolic or solid without pulling the carb and intake manfold?
are the heads worth removing to port? i have a 3 week break from auto tech school so i might dig in and go all out.
i am trying to set lash, and several valves appear to be loose so i am thinking solid lifter
Old Jan 27, 2009 | 05:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: roller tip rocker arms... roller cam? cast #'s inside
No
If there's slack in the valvetrain, it's probably solid... unless it's hydraulic and it's been lashed wrong.
Old Jan 27, 2009 | 06:57 PM
impaled's Avatar
i am thinking it is solid considering that it is a louder valve train than comparable engines and the lash is off.
what is the spec for valve lash on the 350's?
Old Jan 27, 2009 | 07:16 PM
ljnowell's Avatar
Lash spec for a solid cam is generally given by the cam manufacturer. Look to find more lash on the exhaust side. I would pull the intake and verify though, if you are under the impression that you have a solid lifter cam. Lots of different things come into play, not worth toasting it.
PS. I hope they didnt build a solid cam engine with go fast parts and those heads.
Old Jan 27, 2009 | 07:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Find a valve that's closed and tighten the rocker nut down, past zero lash. Hydraulics will have a bit of "squish" in them, on the pushrod side. Solid will immediatly start to open the valve.
Obviously you will have to re-lash.
Old Jan 28, 2009 | 11:42 AM
impaled's Avatar
they are solid lifters. i dont know what the cam is, so what should i set the lash at? i have no idea...
Old Jan 28, 2009 | 12:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You pulled a lifter and verified? Solid flat tappet cams aren't that common, especially if someone did use crappy heads like that. Usually a solid cam is used when people really know what they're doing.
Hence, I HIGHLY doubt you have a solid cam, unless you post a picture of the lifter, and you verify that there's is no spring in the top. Ie you can't push a pushrod into the top AT ALL.
You can grab a rocker and rock it towards the cam with your bare hands. An experienced mechanic should be able to tell you if it feels like there's a spring or not.
Old Jan 28, 2009 | 03:20 PM
impaled's Avatar
i both misread (another's post) and misthought my previous post.
they are hydrolic lifters for sure. i pulled it apart (intake manifold and carb and a little more) and varified that they are hydrolic. the valve train is in rough shape though and i need to replace some things (if not most) and am starting another thread on the top end build.
junkcltr
Aug 2, 2019 11:12 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
