1500 rpm idle?
Old Jan 29, 2009 | 02:30 PM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
1500 rpm idle?
my car was running really rough yesterday and i changed all the spark plugs because i had used some old ones i had, and now the cars staying at 1500 rpms and wont drop down at all, any ideas? i have a carbed 350 4bbl quadrajet computer advanced not vacuum
Old Jan 29, 2009 | 06:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Make sure your choke heater wire is still on the choke thermostat.
Old Jan 29, 2009 | 09:23 PM
fychelio's Avatar
Axle/Gears: ????
Re: 1500 rpm idle?
it was a little loose so i put it on securly.. thanks for that info, now it just idles badly after it warms up like in the rpm gauge you can see it idle up, down, up, down and its around 500 rpms. like it wont stay stable. when i move the throttle the engine seems to rev good (i have no idea how good the distributor is on the car i pulled it from the junk yard cuz my old distributors pick-up coil went out) but the ignition coil is new (replaced it like 5 months ago).
Old Jan 29, 2009 | 11:03 PM
fychelio's Avatar
Axle/Gears: ????
Re: 1500 rpm idle?
code 15
code 41
code 42
i know 15 is coolant temp sensor so its getting replaced.
is code 42 from when i set the timing?
code 41 didnt make sense from the tech faq page.
anyone have code page for the early model ecm's?
Old Jan 29, 2009 | 11:43 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 1500 rpm idle?
If I understand right, you say its hovering around 500rpm, and bouncing around that 500rpm mark? If thats what its doing, bump the idle speed screw up untill its around 800rpm in P or N. Its prossible the idle speed was just way too low, which will make it bounce around and run like crap.
Also, check to make sure all the plugs are tight, and that both ends of the plug wires are snapped on completely and fitting tight to the terminals/plugs. A loose or burned plug wire can also make it run like that. Check this first, before you go playing with the carb adjustments.
Old Jan 30, 2009 | 12:00 AM
five7kid's Avatar
41 would be knock sensor, I believe.
Old Jan 30, 2009 | 02:22 AM
fychelio's Avatar
Axle/Gears: ????
Re: 1500 rpm idle?
checked all the wires and just put new plugs in today nice and tight, the idle air screw is kinda of low so i raised it from the bottom 5 complete turns, i replaced the coolant temp sensor and that code went away, and the only code i get is 44 lean oxygen sensor.
the car runs but has no power as i hit the petal. and takes along time while holding the petal down to gain speed. it drives really slow? is it driving this was cuz of the oxygen sensor?
Old Jan 30, 2009 | 01:46 PM
fychelio's Avatar
Axle/Gears: ????
Re: 1500 rpm idle?
bumb bumb
Old Jan 30, 2009 | 02:51 PM
fychelio's Avatar
Axle/Gears: ????
Re: 1500 rpm idle?
so i replaced the oxygen sensor and it got a little better, basiclly all its doing now is when i drive the car it picks up speed slow, if i accelerate more it will like chug back a few times and pick up more speed. if i floor it itll kick into gear and bone out! but its still lidleing rough and chuggy. anyone think i should get a new distributor? their are no vaccum leaks just checked everything with some carb cleaner.
Old Jan 30, 2009 | 03:52 PM
Joiner's Avatar
Car: 1991 Firebird Base
Engine: 3.1
Transmission: 700R4 Automatic
Re: 1500 rpm idle?
Emmissions could be the problem, my car is idling at around 1500.
Old Jan 30, 2009 | 03:53 PM
Joiner's Avatar
Engine: 3.1
Re: 1500 rpm idle?
If your car has the L69 (4bbl Qjet 305) like mine than it would have the emmissions where they put on an air pump with a v belt that runs air into the exhaust. If theres any problem with the hoses to that or if they were taken off it will make the car run like sh*t, reason mine isn't liking me much lately.
Old Jan 30, 2009 | 07:35 PM
fychelio's Avatar
Axle/Gears: ????
Re: 1500 rpm idle?
thanks, yea one of them wasnt clamped tight it was loose, engine got alot more stable but still not at 100%. im ganna change my coil and see if it does anything.
Old Feb 2, 2009 | 08:07 AM
Joiner's Avatar
Engine: 3.1
Re: 1500 rpm idle?
Found out that I don't have the L69, but the same principle applies.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
forstral
Aug 19, 2015 03:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
