Yet Another Goodie I Discovered From a PO
Old Jan 29, 2009 | 07:55 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
A Spohn Panhard Bar with Poly bushings!
I wonder what other little surprises are on this car I have yet to discover.
If anyone sees anything else they believe to be aftermarket, let me know!
Old Jan 29, 2009 | 10:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Chrome diff cover.
Not sure that's a "goodie", though.
Old Jan 29, 2009 | 11:50 PM
Car: 1985 Z28
Re: Yet Another Goodie I Discovered From a PO
Thanks for clearing that up. I was 90% sure it wasn't stock butt never bothered to check.
About as useful as an antenna ball though. Now if it was one of those aluminum covers with the full and drain holes...
I wonder if the sway bar is stock...itd be wierd to replace the PHB but not the SB...
Old Jan 29, 2009 | 11:52 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Goodies like that are good to find. Lets just hope there aren't any bad goodies IE rust... ETC
Old Jan 30, 2009 | 02:17 AM
Car: 1985 Z28
By the way, dumb question but is my fuel filter visible anywhere in this picture? I have never seen it before and would not know what I was lookig for.
I thought it was that guy on the left for a second but it looks like its going to the brakes...
Old Jan 30, 2009 | 07:10 AM
chevy89camaro's Avatar
you can barely see it.... it looks like its been changed not too long ago. never hurts to put a fresh one in. its right behind the floor pan. low center of pic. kinda shiney and you can see the fuel line wrap around the floor pan towards the tranny.
Old Feb 1, 2009 | 11:10 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Hey it's really hard to see, but it looks like you might have greasable tubular lca's
Old Feb 1, 2009 | 12:46 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I spy tubular lower control arms, and a possibe non-stock Y-pipe
Yes the fuel filter is visible.
Old Feb 1, 2009 | 12:59 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
Rear sway bar looks larger than stock
Old Feb 3, 2009 | 10:49 AM
Car: 1985 Z28
Excuse my noobishness, but where exactly are the LCA's located? I know what they are but not how to spot them.
I will get under today and check the sway bar.
Old Feb 5, 2009 | 05:04 PM
Car: 1985 Z28
Think I found something else that is aftermarket from a PO.
Can anyone tell me if these are actually worth having or if they're one of those bragging rights parts.
Attached Thumbnails Yet Another Goodie I Discovered From a PO-img00065.jpg   Yet Another Goodie I Discovered From a PO-img00066.jpg
Old Feb 6, 2009 | 10:19 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well there noy bad shocks not high end as far as perfomacne but they are good stock replacments. Good news is the lca's in the pic are aftermarket. Some one was doing some suspension mods on that car.
Old Feb 6, 2009 | 02:08 PM
Car: 1985 Z28
I checked and know that the front LCA's are stock, but I'm not sure how to identify the rear LCA's...
Can someone point them out?
Old Feb 10, 2009 | 12:05 PM
Toehead's Avatar
Sure thing. It is the square tubing member running perpindicular to the shock in the second picture.
Old Feb 10, 2009 | 12:25 PM
Car: 1985 Z28
Ah you are referring to the box style part that looks blacker than anything else in that picture?
I knew those weren't stock but didn't know they were the rear control arms
They have poly bushing also .
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
