cam upgrade question!
Old Feb 2, 2009 | 12:00 AM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
im wanting to upgrade my cam and was looking for some opinions on my selection.
the cam i am running now is pretty conservative for my motor and its inccome tax time so now is the time to get this stuff i am also lookig at getting a better converter
here is the cam i am thinking of! i would also be getting good valve springs and supporting hardware
Solid roller, rough idle. Excellent cam for high performance street/strip applications. Excellent mid to upper RPM torque and horsepower in 355-383 cubic inch engines. Needs 3000-3500 RPM stall speed converter, 10:1 or better compression, aftermarket exhaust system and 3.90 rear gear ratio
  • Advertised Duration (Int/Exh): 279/285
  • Duration @ .050 (Int/Exh): 249/255
  • Gross Valve Lift (Int/Exh): .585/.600
  • LSA/ICL: 110/106
  • Valve Lash (Int/Exh): 016/016
  • RPM Range: 2800-7200
Old Feb 2, 2009 | 10:21 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: cam upgrade question!
Do you think you can get that beast running with FI? I'm not sure how picky HSR is, but that's a beast of a cam.
You'd probably need to upgrade your stall speed, and valve springs, maybe a stud girdle as well. Poly locks too.
What heads are on the car? Keep in mind this would be a 3500-7000RPM cam...
Old Feb 2, 2009 | 10:54 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
the heads are patriot 195's and i would be getting a pi vigilate 3200 converter
and the proper valve springs and locators & retainers
as far as tunning i dont think it would be that bad and i could always run it in alpha n at idle, i dont think its that radical and im rying to stay away from comp cause evreyone runs their cams
Old Feb 2, 2009 | 10:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Who makes the cam?
That isn't an EFI grind, not even close.
Old Feb 2, 2009 | 11:02 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
its a lunati voodoo solid roller!
i have a aftermarket ecu so tuning is not a problem
Old Feb 2, 2009 | 11:04 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Why do you want SR?
Old Feb 2, 2009 | 11:17 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
no preferece really it just seemed to fit my build. the car doesnt see too much street use and even though its a solid cam being that its roller it shouldnt frequent near as much adjustment
Old Feb 4, 2009 | 01:16 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
well i have been thinking and i think im going to go with the voodoo 60132 its one step down from the one above it has a dur @ 050 of 241/249 .579 .585
anyone have any experience with this cam
Old Feb 6, 2009 | 12:41 AM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
anyone have any input?
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
