air foil worth it?
Car: 87 Iroc-Z
Engine: 305 5.0
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: air foil worth it?
10 horsepower outta the box
well little stuff like that wont make much of a difference when driving around town. but that added up to some more small modifications, like a ram air setup, de screened MAF, siamesed intake runners and plenum, then you might feel it
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Unless you have some serious mods done to your intake or the airfoil is only about $20 it's a waste of money.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
If the stock throttle body is your bottleneck, it works wonders. However, if your throttle body is the major bottleneck, you'd be much smarter upgrading to a bigger throttle body, which have these things made into them.
TA
Car: '89 IROC-Z
Engine: LSx
Like stated above, its just a supporting mod, by itself its pretty much useless, but put in with a some other decent engine mods and it might do you some good.
Car: 1986 Irocz
Axle/Gears: 3.25:1
I still think there should be a sticky for airfoil questions.
https://www.thirdgen.org/forums/tpi/...i-airfoil.html
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
I have one I no longer use since upgrading to a bigger TB with the splitter already shaped as an airfoil.
If you plan to get one anyway, $20 + shipping and it's yours. PM me.
It's a TPIS, which is a little better looking piece than the one shown in your link.
Car: 1991 Chevrolet Camaro Z28
Engine: 5.7L 350
Honestly I did notice a difference when I first put it in. Car seemed to pull a little harder. Nothing major, but I could tell the difference.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I've always said its better to get a 52mm throttle body with an airfoil already in it.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
By itself, on a stock engine, pretty much worthless...
