Oily plugs?
Old Feb 4, 2009 | 01:43 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Oily plugs?
Pulled out a couple of plugs to check for a hard to start condition, and random dying. A few of them had oil on the threads. Was wondering how bad this is?
Old Feb 4, 2009 | 01:54 PM
RobSS1113's Avatar
Re: Oily plugs?
is it just oil on the threads or is the part that actually goes into the block Wet with oil ??
sometimes the threads get wet when you take them off or put them in because you've got oil leaking from the valve covers
Old Feb 4, 2009 | 02:02 PM
kcallais's Avatar
Car: 1985 Z28
Re: Oily plugs?
The threads were pretty wet. the actual electrodes werent. Just a bit of carbon buildup. Worried about bad piston rings =/
Old Feb 4, 2009 | 02:17 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Oily plugs?
I wouldnt worrie too much then as stated earlier oily threads could just be as result of a leak. Bad rings will show with blue smoke that hangs in the air like ww2 battleships exhaust. Oil on the electrodes would mean something but if its not on the electrode no need to even get into that.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
