HELP!!!! engine turns over hard and slow
Old Feb 4, 2009 | 06:20 PM
esherman's Avatar
I got a 88 irocz28 and thinking about buying this 92 rs with a 305 tpi. but the guy says it turns over hard hes got 4 plugs out and the serp belt off and it still does it. any thoughts of what to try to get it running??????
Old Feb 4, 2009 | 06:55 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: HELP!!!! engine turns over hard and slow
with the plugs out,you should be able to turn the crank
pulley by hand-if it doesn't engine may have spun
bearing,if it does turn by hand there is a starter motor
or wiring problem.
Old Feb 4, 2009 | 07:24 PM
esherman's Avatar
idk he said that the starter sometimes doesnt catch and he thought it needed to be shimmed. any thoughts on that???
Old Feb 5, 2009 | 01:01 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
when you start it does it move the pullies to ? if they move then odds are the starter is fine
Old Feb 5, 2009 | 10:12 AM
DJ_SirG's Avatar
Car: 1986 Trans AM tpi
Transmission: A4
Axle/Gears: 277 Posi
Easy Easy now...... There are only three facts turning over the motor. The power (battery) power distrabution (starter) and resistance (compression). If you have 4 plugs out of the motor then Compression is out. First thing to check is Battery. Voltage check will do nothing for you, you need to check amps. There is no GOOD way to check the amps if you are a noob. Put a knowen good Battery in the Car and attempt to start. If this do nothing for you. Take the starter out and have it tested. Most Auto parts stores will do so at no charge. If you have a NEW battery and NEW starter...... Do it anyway. Youre starter NEEDS amps and from time to time you will get a NEW battery that is bad. I got one from Wallmart just 5 months ago. Last month a got a NEW starter from Schucks that took me a houre to put in just to find the NEW starter was bad......
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
