Spring Tune Up
Old Feb 8, 2009 | 12:08 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Spring Tune Up
I have a 1988 Trans Am GTA 5.7LTPI , and I'm planning my tune up parts so I'm ready to go come spring time. So this is what I am thinking. For plugs, I want to get some NGK Iridium LXs (link), black MSD Super conductor wires (link), Accel Cap and Rotor (link), and then i'm going to put Mobile 1 Full synthetic 5W-30 oil in it. I was also going to put Zmax in the fuel and oil systems. I always use premium gas in it too, so after I do this tune up, it should run super smooth. So, what do you guys think?
Old Feb 10, 2009 | 08:27 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: Spring Tune Up
I guess i need to be a little more clear. Is getting the really expensive stuff worth it?
Old Feb 10, 2009 | 08:46 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Spring Tune Up
It's a matter of opinion. Mine is no, not even remotely worth it. Put your money where it will do some good like headers.
Old Feb 10, 2009 | 10:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Spring Tune Up
I agree, if the motor is pretty much stock - or even if it isn't you're not going to be gaining anything by running $6 spark plugs. Maybe .00000001 in the quarter mile via the lighter wallet. Run your standard .99 cent delcos or regular old Boschs and be off with it. If you need new plug wires, rotor, and cap, then what you are looking at will suffice.
Old Feb 10, 2009 | 10:22 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Spring Tune Up
do some love maintence like
flush the brake fluid
flush tranny
new gear oil
pack the front wheel bearings
she will love on ya
Old Feb 10, 2009 | 10:32 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: Spring Tune Up
well im also going to flush coolant, and change the tranny oil. maybe the diff to. I know the stuff wont get me any power, I really want it to idle smoother.
Old Feb 11, 2009 | 08:49 AM
jamon8's Avatar
Engine: 350 tpi
Re: Spring Tune Up
you will be supprised if you change the diff fluid and pack the front wheel bearings
less rolling resistance= freed up hp
no one wants to flush the brake fluid but they cry when the calipers stick and wheel cly leak so just gravity bleed them out and presto less problems
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
