How to prevent spark plug wires from touching manifold?
Old Feb 10, 2009 | 01:55 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Whats the easiest way to do this because I have melted about 4 out of 8 of my spark plug wires and am about to put new wires in. How do I go about preventing them from being melted?
Also sorry I couldn't use the search. I have to go to an appointment and want to work on my camaro right when I get home to get some things done before dark. Thanks,
Justin.
Old Feb 10, 2009 | 02:19 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: How to prevent spark plug wires from touching manifold?
Is this why your camaro wasn't starting? I would use the guides. You can get a set that bolt onto your valve covers and guide them away from the manifolds.
Old Feb 10, 2009 | 03:27 PM
PROPHET69's Avatar
Car: Modified 1985 Z28
Engine: 355 Carbureted
Transmission: TH350 Turbo
Use tie-Straps, I had the same issue. Just take a couple wires and tie-strap them together or to the valve-cover screws.
Old Feb 10, 2009 | 04:01 PM
JTNKTZ's Avatar
Engine: 355/350
Nah this is on my 91. My 89 isn't starting.
Old Feb 10, 2009 | 04:15 PM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
I had the same problem years ago, so I bought Taylor heat sleeves from summit and have had a problem since.
Eric
JTNKTZ's Avatar
Engine: 355/350
Eric
You have had a problem? Rut ro what was it? :P Typo.
Old Feb 10, 2009 | 04:24 PM
Melting plug wires, now they can touch all they want and nothing happens.
Old Feb 10, 2009 | 04:25 PM
JTNKTZ's Avatar
Engine: 355/350
Eric
I think you meant have not had a problem since. :P
Old Feb 10, 2009 | 05:08 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Eric
Like he said get some of these, all the race cars have them to keep the wires from melting on the headers. They may look expensive but trust me i use them they really work. Mine sit right on the headers and have NEVER melted a wire.
Old Feb 10, 2009 | 05:58 PM
Yes I'm sorry, I did mean "haven't had a problem since". I have 1 3/4" headers and my plug wires also sit on my headers or are very close too.
Eric
Old Feb 10, 2009 | 10:34 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
run then under the manifolds or headers
Old Feb 10, 2009 | 10:46 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
nope, i tried this on mine and thats how they got burnt.
i was trying for a cleaner look.
now i need new wires.
although in the defense of routing them under the headers, mine are universal, not fitted, so that could be part of the problem.
Old Feb 11, 2009 | 08:52 AM
jamon8's Avatar
Engine: 350 tpi
you have to have universal wires to fit it all up right
under the headers is the cleaner look
go to jamon8.com and look at my tpi setup
I think it looks good without all those wires hangin out covering my mt valvecovers
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
