need help.....
Old Feb 10, 2009 | 10:25 PM
rolly92cam's Avatar
need help.....
ok so i bought a 91 z28, the guy said it has a 350 5.7 of a 89 iroc-z, but im not sure i toke it to the track an i hit a 14.9 but that dosent tell me much cause i havent done oil change, an i dont know how good the sparks, an wires how can i find out what it is, cause i want to buy some performance stuff, please help.
Old Feb 10, 2009 | 10:29 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: need help.....
Welcome aboard.
Check the casting number on the back of the block, then take that number to http://www.mortec.com/castnum.htm and look it up. Will tell you pretty quick what it is. As for performance stuff, though, when it comes to getting bolted to the outside (like heads, headers, intake, etc), most stuff doesn't care if it's a 305 or 350. Bolt patters are the same.
Old Feb 10, 2009 | 10:46 PM
rolly92cam's Avatar
Re: need help.....
thanks man, im going to do that first thing tomorrow.i hope its a 5.7. p/s do u know if the
airfoil works.
Old Feb 10, 2009 | 11:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Re: need help.....
On a stock motor, not worth it.
Old Feb 11, 2009 | 10:33 PM
rolly92cam's Avatar
Re: need help.....
well it has headers, 3.73, shift kit, an some new drag radials, what can i put to give it some good power.
acerocks666
Aug 24, 2014 07:37 PM
RichSmoke
Aug 14, 2014 02:29 PM
niGhTcrAwler1
Jun 22, 2013 10:41 PM
beaner104
Apr 17, 2013 05:55 AM
bert89
Oct 31, 2005 11:10 AM
