%^$* holley regulators
Old Feb 11, 2009 | 03:39 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
ok guys i been threw 3 freekn holley fuel pressure regulators that summit sells. they will NOT seal at all. ive used teflon paste and tape. the leak on all the ports in the regulator. i got a dual feed one and it sucks. anybody know how to fix it or should i get a new one?
Old Feb 11, 2009 | 05:37 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: %^$* holley regulators
Thats odd. I probably use the same one you have and have had no trouble with it. For starters keep in mind you dont want to use teflon tape because gas eats it. Second the regulator is designed with pipe treads (i think 3/8 NPT?) are you sure your using the correct adapters?
Old Feb 11, 2009 | 06:50 PM
Engine: 355
go figure the whole stupid *** problem was the fittings. the had chrome on the threads which wasnt allowing it to seal. i sandblasted cleaned and put on. no more leak. odd
Old Feb 11, 2009 | 07:52 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Chrome never seals. Chrome timing covers and oil pans, for example...
Old Feb 12, 2009 | 02:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Where did you hear gas eats Teflon tape?
It doesn't.
Old Feb 12, 2009 | 06:28 PM
Engine: 355
i havent heard that eihter. anybody kno how to quiet down an electric inline pump> its insanely loud
Old Feb 12, 2009 | 06:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How do you have the pump mounted?
Old Feb 12, 2009 | 06:49 PM
Engine: 355
i hveit mounted below the tank on the rear seat area of the outside, i have rubber washers in between but its stil loud
Old Feb 12, 2009 | 07:19 PM
I could be mistaken but i believe i remeber reading it in one of hollys instructions that came with a fuel line kit. Its been a while ill have to check again but im pretty sure the spelled out specifically no teflon tape on fuel fittings. Now i know theres a yellow vertion of teflon tape specifically designed for gasoline applications and the teflon paste is ok but my understanding is regular white teflon tape is a big no no for applications where it will come in contact with gas.
Old Feb 13, 2009 | 08:50 AM
50bmgshooter's Avatar
Originally Posted by billybob6110
i haven't heard that either. anybody kno how to quiet down an electric inline pump> its insanely loud
witch pump are you running the old style 110 and 140 pumps (red or blue ) were always loud
Old Feb 13, 2009 | 03:03 PM
Engine: 355
i have the summit brand pump. i think its a trickflow pump
RedLeader289
May 28, 2019 01:47 PM
Mark_ZZ3
May 24, 2018 01:02 PM
gixxer92
May 18, 2017 11:20 AM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
