rods hitting cam
Old Feb 15, 2009 | 08:35 AM
cmack's Avatar
Car: 1983 camaro
Engine: 383sbc
rods hitting cam
I am building a 383 for my 1983 camaro i have cleranced the block for the crank and the rods but when i installed my cam number 1 and 5 connecting rods hit my cam i was wondering if anyone has experanced this and any advice you cound give me thanks
Old Feb 15, 2009 | 08:58 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: rods hitting cam
http://www.carcraft.com/techarticles...y_stroker.html
Old Feb 15, 2009 | 09:54 AM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Yeah you have to use the small base circle ground cam. requires different timing set as well
Old Feb 16, 2009 | 03:15 PM
cmack's Avatar
Car: 1983 camaro
Engine: 383sbc
i was told i could grind my rods by my local machine shop to clear the cam as long as it is balanced after
Old Feb 16, 2009 | 07:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It depends how much you're taking off, and where. Usually it's the shoulders of the rod bolts that need to be clearanced, and they're iffy enough strength-wise even before you start grinding on them.
Did you install the cam before or after the crank and pistons?
Old Feb 16, 2009 | 07:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It does?
Old Feb 16, 2009 | 07:23 PM
cmack's Avatar
Car: 1983 camaro
Engine: 383sbc
i installed the cam before the rods i also have arp rod bolts not studs and nuts
Old Feb 16, 2009 | 07:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Which rods are you using then?
Old Feb 16, 2009 | 07:53 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
never had to clearance for my cam. weird. and no you do not need another timing set. double roller i suggest f you dont already have one
Old Feb 16, 2009 | 07:56 PM
jjlabinski's Avatar
Engine: shinny 350
I forget the exact difference but much to my surprise a few years back there is a difference. I could go look cause I have both cams but I think the bolt pattern is different for the small base circle cam or it had to do with the back face. I could look next time I go outside.
Old Feb 16, 2009 | 08:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
There shouldn't be any difference in the timing set, as the only thing different between a generic cam and a small base circle cam is that the lobes are smaller. Timing end of it is the same.
Old Feb 17, 2009 | 03:25 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There isn't, and it's not.
Old Feb 17, 2009 | 08:46 AM
ssean92's Avatar
Car: sold
I used a small base circle cam, well after the rods took out the cc306
Old Feb 17, 2009 | 02:36 PM
creese187's Avatar
yeah, i would look into the small base circle cam, i have a 383 small block, with a .600 lift cam, and even with the huge eagle h-beam rods, i still had plenty of clearance, call comp, that what cam i have, they should set you straight
Old Feb 17, 2009 | 05:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's the duration that causes more problems than the lift.
Old Feb 17, 2009 | 10:07 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Yes I had the same problem and my heart sank and I broke out in a cold sweat when it happened. I ground down the rods a little to clear. Here are the before and after pics.
Old Feb 18, 2009 | 04:25 PM
Air_Adam's Avatar
The only way I can think of there being a difference is if one was drilled with the pre-roller-block bolt pattern, and one was drilled with the GM-roller-block bolt pattern, as I think the GM-roller-block timing gear bolt pattern was slightly smaller on the camshaft, because of the retainer plate IIRC.
I could be wrong about that, I`m not 100% sure here. I remember hearing about that somewhere a few years back. Has nothing to do with whether or not its a small base circle cam though.
Old Feb 18, 2009 | 04:37 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
This is the same action I took in my 406. 270 Comp cam, Eagle 5.7 inch I beam rods...a little grindage and no more rubbage. 36,000 miles no problems.
gixxer92
Sep 1, 2015 04:32 PM
anesthes
Aug 26, 2015 01:37 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
