cam question????
Old Feb 16, 2009 | 05:49 PM
my90bird's Avatar
Car: 1990 firebird formula
Engine: 5.0 tpi
Transmission: t-5
cam question????
can I run a retro fit roller cam in my 90 factory roller block?and what would happen if i ran a non-computer controlled cam in my car?
Old Feb 16, 2009 | 07:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: cam question????
It will fit. You will need an early model cam plate, thrust button, and early model timing set. Most people use a factory roller cam in factory roller blocks
Depending on size, many non-cc cams running in computer controlled cars end up running like junk until they're properly tuned.
Old Feb 16, 2009 | 07:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No cam plate.
Old Feb 16, 2009 | 07:14 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Cam locking plate...
Old Feb 16, 2009 | 07:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
One of these?
You can use one if you want, but it's not necessary.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
