no oil pressure
Old Feb 17, 2009 | 05:54 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
no oil pressure
ok having a problem with the firebird. When i first start the car up in the morning it has no oil pressure until the engine warms up. Its not low on oil and after it warms up no problems at all and its back to the normal 25-35 lbs. What could cause this? I am about 500 miles overdue on a oil change but i wouldn't think that would cause this
Old Feb 17, 2009 | 10:09 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: no oil pressure
If you're really worried about it you could replace the pressure sending unit with a guage to know if it's a sending unit problem, a wiring issue that is affected by heat, or a real issue with the lubricating system. That's the only sure-fire way to separate a possible bad problem from an easy fix.
I'm no expert by any means, but I find it hard to believe you would have low pressure until you were at operating temp. My best guess is an electrical issue or the sending unit.
Old Feb 17, 2009 | 10:29 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: no oil pressure
If you really had no oil pressure it wouldn't be running any longer. You might try a new sender or a mechanical gauge.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
