need to know if it will hold...
Old Feb 23, 2009 | 04:43 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Im building a 383 stroker and should be putting out about 450-500 rwhp and wanted to know what rods (I or H Beam) and if a cast crank will hold up to that kind of hp.
thanks,
Chas
Old Feb 23, 2009 | 04:59 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Re: need to know if it will hold...
Your getting pretty close to what a cast crank can handle, i believe eagle/scat rate their nodular iron cast stuff at 500fwhp. I would urge you to go for a forged crank, ohio crankshaft sells 5140 forged cranks for dirt cheap (they also sell premium 4340 if you can afford it). Ss far as rods go, decent I-beams will be fine, something like scats pro-comp series with 7/16 rod bolts.
-Zander
http://www.ohiocrank.com/chevysb_cranks.html
Old Feb 23, 2009 | 07:51 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
i was referred to http://www.pawinc.com/ for rotating assemblies and parts...best prices i have been able to find anywhere...i read that scat can get 600+ out of their cranks...is that rwhp or crank hp
Old Feb 23, 2009 | 07:56 PM
the zander's Avatar
Good prices, Personally I like cnc-motorsports
This kit, or somthing like it, will stand up to your intended application.
http://www.cnc-motorsports.com/produ...358&CtgID=9011
-zander
HiPerf_Chevyman
Sep 22, 2007 04:55 PM
fogrocker
Apr 27, 2007 04:52 PM
deadbird
Jun 1, 2005 11:14 AM
RedWagon42
Carburetors
Nov 11, 2004 12:14 PM
darkvengence
Dec 5, 2001 07:48 PM
