Can i use this engine for my camaro?
Re: Can i use this engine for my camaro?
All that being said, remember, when a chevy gets sold all 305s are 350s and all 350s came from corvettes. There are far more corvette engines being sold than there was corvettes being made.
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
also be aware, motor oils no longer have the necessary additives in them for a flat tappet cam engine. it sucks, but it is what it is. i'm having a problem with my car right now that has an 85 305 TPI in it with flat tappet lifters, I think the lifters are eating up the cam, and now I have a knock somewhere.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Transmission: 4L80E/4L80E
Just use a diesel oil that's rated CI-4+ and SL. It'll have the antiwear additives.
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
It it is a real LT1 from an old corvette thats a pretty stout motor. Although keep in mind it is old and if it hasnt been rebuilt you might have to spend money on top of it to have it rebuilt (which can be pricey). Also you need to make sure it has harden valve seats for use with unleaded gas otherwise youll run into issues at some point. I run a 70 corvette LT1 and i think its great would be nice to have a roller cam but its fine with the right oil. I run eather valvoline VR1 or Rotilla T.
Probably true. Get the head casting #'s, that'll tell you more than anything.
The only flat tappet cams I've seen wiped out were from 60's engines back when the anti-wear additives were still in the oil in full force.
But, I still use CI-4+/SL synthetic in my one remaining flat-tappet engine.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
