Can I swap this in my Camaro?
Old Feb 25, 2009 | 06:06 PM
88beast's Avatar
Will a 302 from a 85 mustang gt swap into my 88 Camaro with a 305 v8 tbi?
Old Feb 25, 2009 | 06:12 PM
Ruiner's Avatar
Car: '91 Camaro RS
Engine: 355 TPI, Comp 268xfi, bowtie heads
Re: Can I swap this in my Camaro?
anything's possible, with a lot of custom work.
At the very least you'll need custom motor/tranny mounts, driveshaft, wiring, probably not worth it
Old Feb 26, 2009 | 12:32 AM
toomany's Avatar
As Ruiner said, it's possible. But why would you even want to do that? It'd be way easier/cheaper to drop another SBC in there.
Old Feb 26, 2009 | 12:51 AM
Stephen's Avatar
Car: 87 GTA
Possible, but a lot of custom work to fab motor mounts, tranny mount (can't use the GM tranny anymore).....
The tranny will hafta have the correct drive line angle for the driveshaft, which in turn affects the pinion angle of the rear end (and the resulting custom mounts, either a torque arm or a 4-link).....
Don't forget, unless you swap in a Ford 9" rear end, your gonna need a custom driveshaft, to deal with a new resulting length AND mating a Ford u-joint on one end, then a GM u-joint on the other.
I can't think of any way it could possibly be worth the effort.
Old Feb 26, 2009 | 01:06 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Correct me if I'm wrong, but even if he used a ford 9 inch, he'd still need a custum shaft for the new length because mustangs and camaros wouldn't be the same length between the rear end and the end of the trans tailshaft? This swap is totally not worth it, no matter how cheap or free that 302 is.
Old Feb 26, 2009 | 01:37 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
sooo beyond the fab work you COULD use A tranny from a camaro, kinda
BW whored out the t5 to both GM and ford so as far as dimensions go the t5 would fit
Old Feb 26, 2009 | 02:15 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Yes, but I think the input shaft has a different spline count... Hey, Andy! I think if he already has no friends or just likes being an outcast, go for it!
Reminds me of a guy at the car show I go to on friday nights: 95 Must@$# with a LS-2 in it. The mustang guys wont let him park with them and we wont let him park with us!! He has to park with the ricers and they just ignore him.... Sad.
Old Feb 26, 2009 | 02:49 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
yup different bellhousing and spline count, we get all out extra t5s from bondurant (dunno how to spell it) i.e the mustang graveyard the splines on the ford t5 are considerably larger and lower count lol
Old Feb 26, 2009 | 08:36 AM
Stephen's Avatar
Car: 87 GTA
I mentioned the driveshaft problem in my reply, just above yours.....Among other problems.
Yeah.....Wrong bellhousing.....Wring output shaft (spline count). Then there is the shifter linkage up into the car to deal with & clutch pedal.
And that assuming a manual tranny, not an auto tranny.
Old Feb 26, 2009 | 11:43 AM
Plus having people pee on, and egg your car. (The guy I was talking about has a Bowtie and "LS-1" sticker on his back window) I guess that enrages the mustang guys. It's just too much trouble for the beating you will take from the purists.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
bellez77
Sep 5, 2015 08:39 PM
InfinityShade
Aug 22, 2015 08:00 PM
reiderz iroc
Aug 13, 2015 04:57 PM
