EGR Solenoid
Old Feb 26, 2009 | 04:06 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
EGR Solenoid
So I broke one of the plastic vacuum hose pegs clean off my egr solenoid . . . am I pretty much high and dry for like $80? Most places don't even sell the egr solenoid, thats the best i could find.
anyone know of any way to either adapt the existing solenoid (i dunno, drill out the hole and put in a new hose barb or small pipe of some sort) or adapt a solenoid from something else to fulfill the same role? Paying $80 for a piece of plastic is ludicrous!
Old Feb 26, 2009 | 05:36 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: EGR Solenoid
Well if your really desperate and willing to just take a chance assumeing you still have the other piece is take some 2 part plastic epoxy and find a drill bit exactly the same inside diameter as the vaccum port. Then slide the round end of the drill bit down the broken piece of the EGR solenoid and into the solenoid itself. Put a liberal amount glue on the end of the broken port and reattach it to the solenoid. The drill bit will not only keep the Broken port lined up but will also in theory keep the glue out of the solenoid and the port itself if you chose the right size. Its also important if you want to get the drill bit back out though that you twist it while the glue dries so it isnt glued to the EGR solenoid as well. Might work for ya unless someone else has a better idea but on the bright side what do you have to lose?
Old Feb 26, 2009 | 06:54 PM
Naft's Avatar
Re: EGR Solenoid
great thinking, i just hope there is enough wall thickness on the barb for the glue to hold
Old Feb 27, 2009 | 03:03 AM
batman-matt's Avatar
Car: looking for my camaro again
Engine: 350 5.7L 150HP w/. injectors
Re: EGR Solenoid
I myself need just a new EGR solenoid any clue where to find one? nothing is broke on mine however (thank god) I would have gotten a little nervous if that happened to me
Old Feb 27, 2009 | 03:07 PM
Naft's Avatar
Re: EGR Solenoid
well it turns out mine was salvageable, although the drillbit gluing didn't work.
I've got an extra used solenoid that i got to replace mine, i'll get that to you at my cost (probably around $20 with shipping) if you're interested. As far as new goes, i dunno. parts america has a few listed for online order around $90 but im not sure they're even in stock.
if you are interested send a pic of the connector on yours to make sure its the right fit eg.example(a)gmail.com
Old Feb 27, 2009 | 10:22 PM
Re: EGR Solenoid
i am thanks it'll be awhile since im still looking for a job but if that happens within the next few weeks you've got a deal
Old Feb 28, 2009 | 08:29 AM
spun350's Avatar
Re: EGR Solenoid
I hate to say this but i need one too! I've found 3 sites that have them in stock: www.discount auto parts.com $49.67+ship at $15.46 in all $65.12 oem #1997171.www.bbauto parts.com $49.91 shipping unknown but i guess that it would be close to $15.46. oem #1997171amazon.com $67.59+ship at $9.12 but keep in mind that the oem # is for the motor that im working on is out of 1991 305 tpi speed dens the # is for egr solenoid !!!! good luck :-) OK this may sound "stoopid" but can u guys tell my how to use the smiley faces at the right of the text screen ?!!!Thanks!
Old Mar 3, 2009 | 04:56 PM
Naft's Avatar
Re: EGR Solenoid
sure thing batman just shoot me a pm
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
