Anyone have any underhood shots of a factory ish TPI engine?
Old Feb 26, 2009 | 07:21 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'm looking for good quality underhood shots of factory or close to factory TPI engines. These will be a valuable resoucre for me as I'm in the final stages of reinstalling everything after my 305 to 350 swap. I want to route wires and hoses as close to factory as possible so whatever pictures you guys could provide would be of geat help. Thanks!
Old Feb 27, 2009 | 03:00 AM
batman-matt's Avatar
Car: looking for my camaro again
Engine: 350 5.7L 150HP w/. injectors
Re: Anyone have any underhood shots of a factory ish TPI engine?
yes in fact i have a completely stock 92 z28 5.7 tpi minus the injectors i'll post some pics tomorrow. Will that work for you?
Old Feb 27, 2009 | 04:58 AM
Philerup's Avatar
I got 1 pic on my garage page. 85 TPI, Wish i would have know this earlier today I could have taken detailed pics b4 I pulled the engine. You mite be able to zoom in on the one pic I got.
Old Feb 27, 2009 | 07:01 AM
FUNIROC's Avatar
Car: 1989 IROC
Here this should work. I have it set for MSWORD in Landscape.
1989 IROC Engine 1.doc
Old Feb 28, 2009 | 07:51 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Attachment 172652
Outstanding work and an excellent example of mint factory. Where has this car been "sleeping"?
Old Feb 28, 2009 | 10:40 AM
89RsPower!'s Avatar
yes that pic helps a lot actually, if you guys have any closeups, different angles keep em comin I'm trying to go with factory routing for everything and all factory pieces are going back on..
Old Feb 28, 2009 | 12:01 PM
FUNIROC's Avatar
Car: 1989 IROC
That 1989 IROC has been on ebay a few times. It has very low miles and still looks like it is sitting on the dealer showroom floor. I saved the pictures for my own 1989 restore project.
Best looking all original car I have seen, even down to the original tires.
Old Feb 28, 2009 | 03:36 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Check my sig link and it has a couple engine pics. If you want more I can take them.
Old Feb 28, 2009 | 04:01 PM
CTitalian3's Avatar
Car: 1992 Chevrolet Camaro-Z28 25thAnniv
Engine: L98 5.7L TPI
This is my 92 Z28. It is the L98 5.7; Hope it helps you out
Old Mar 1, 2009 | 12:50 AM
89RsPower!'s Avatar
that does help, keep em comin! Does anyone have a picture of how the hose goes from the washer motor to the wipers? I can't figure out how to route it..
Old Mar 1, 2009 | 09:48 AM
Engine: 350 4BBL
That's a tough one for pictures because it is underneath everything. On my '88 TA it comes out of the firewall at the bottom right corner of the headlight door control module, across the top of the bracket of the brake booster, down to the fender well underneath the main wire harness shown in the first pic. Then along the fender well under the booster where it is attached to the wire harness "tray" with a tywrap shown in the second pic. It hugs the fender well all the way to the washer motor.
Attached Thumbnails Anyone have any underhood shots of a factory ish TPI engine?-100_0342_c.jpg   Anyone have any underhood shots of a factory ish TPI engine?-100_0331_c.jpg
Old Mar 1, 2009 | 12:36 PM
89RsPower!'s Avatar
thanks for the pic, ok so I'm assuming there's a hole under there somewhere that it goes through.. just gotta find it now..
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
