Solid roller cam with hydraulic roller lifters?
Old Feb 27, 2009 | 10:03 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Im not sure what the difference is between a solid roller and hyd roller cam so i was wondering can you use hyd roller lifters on a solid roller cam?
my oil pump failed and the cam got scored by the bearings so instead of turning it i was going to replace it.
Found a cam with the specs i want but it says its a solid roller cam i dont know what the difference would be the both use roller lifters so im not sure it would be an issue.
Old Feb 27, 2009 | 11:25 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Solid roller cam with hydraulic roller lifters?
I suppose you could try it, but I don't think I'd suggest to. The solid roller cam has faster ramp rates than a hydraulic roller and would probably want more valve spring. I know they take a lot more spring when used normally with solid roller lifters.
Old Feb 27, 2009 | 11:48 AM
gapimpin's Avatar
Engine: 383 LT1
i got some nice double springs on there so i think im good there any other issues it might cause though?
Old Feb 27, 2009 | 12:00 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Solid lifter cams take way more pressure than hydraulics, without the pressure (180-200#) the cam will beat the crap out of the lifters. Hydraulic lifters won't take that much pressure.
Best advice....don't do it.
Old Feb 27, 2009 | 02:18 PM
gapimpin's Avatar
Engine: 383 LT1
thats what i was looking for thanx...
Guess ill start looking for another cam.
Jorlain
Oct 8, 2015 01:57 AM
Strick1
Sep 4, 2015 07:11 AM
jtwoods4
Sep 3, 2015 05:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
