Intake manifold won't fit
Old Mar 3, 2009 | 02:31 PM
LouStugots's Avatar
Car: 2006 VW Jetta GLi
Engine: 2.0t
Ive been putting together a 350 tpi system and just got a set of procomp 3003a heads. when i went to install the tpi intake manifold it was about an inch to narrow. When i tried to line up the original manifold that came off this same block it was the same thing, so obviously the heads require a different size manifold but what? am i dealing with vortec style heads here, i have no idea what i need to be shopping for. also does any one know of any adapter plates?
Old Mar 3, 2009 | 03:11 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Intake manifold won't fit
Just did a head swap, no block machine work?
Old Mar 3, 2009 | 10:43 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
You might find this thread interesting: https://www.thirdgen.org/forums/afte...num-heads.html
Old Mar 9, 2009 | 08:47 PM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
if you order those heads through ebay, your fine cuz the guys inspect them b4 they sell them. if they have any casting flaws they get a new set. you wont receive a bad set.
anyway, for your question loustugots, i asked the company on ebay if they were a vortec style head, ill be receiving the answer soon...
ive read of a similar problem on here too... not sure wut the remedy was... ill do some searching and get back to you, in the meantime keep us posted if u find a fix let us know
actually,jv9999 had that covered, but to make it easier... here is wuts in that article
" The stock TPI intake would not seal to the head mating surface. The GM intake's flange is not straight across, it has a recess in the left front and the right rear, after the center bolts. This left a gap of about 1/4". Solution was a different intake ( I went with the Scoggins-Dickey Vortec TPI base)."
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
