89,305,tpi dies
Old Mar 3, 2009 | 10:01 PM
89used2roc's Avatar
89,305,tpi dies
ok car runs great at idle and will even accelerate to a specific point in the throttle probly 1/4 thottle or less it's fine 1/4 thottle or more it falls on it's @$$ kinda like if ya pulled 4or5 plg wires off any ideas?
Old Mar 3, 2009 | 11:09 PM
allred's Avatar
Car: 1986 IROC-Z
Axle/Gears: 10 bolt w/ 3.73's
Re: 89,305,tpi dies
can you check codes, or pids? any kind of scan tool other then a code reader?
Old Mar 3, 2009 | 11:32 PM
89used2roc's Avatar
Re: 89,305,tpi dies
yea i used the ses light with a jump wire and got a tps code so i replaced it and tryed adjusting the new abjustble tps and reset the code didn't fix got the code again
Old Mar 4, 2009 | 05:48 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
Re: 89,305,tpi dies
had the same prob... ended up being 1 single injector. try to ohm test them.
Old Mar 4, 2009 | 07:13 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: 89,305,tpi dies
how did you set the tps
Old Mar 4, 2009 | 08:03 PM
89used2roc's Avatar
Re: 89,305,tpi dies
yes just adjusted the tps for a second time just to make sure it was right then i unpluged the ecm power wire to reset code and them took it down the road same issues and i now have a code 21 and code 43 starting to think it's the ecm or possible ground from the ecm just wonding if the car would still run with a bad ecm also does any one know off hand is there a ground from the ecm to somewhere under the dash
Old Mar 4, 2009 | 08:51 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: 89,305,tpi dies
code 21= tps which you have already adjusted ,code 43= electronic spark control, check that ecm A-B connector terminal b-7;it should be over 6 volts unless the system is sensing detonation. check for a loose connection. replace the esc sensor and/or module. this is according to my manual,jimmy
Old Mar 5, 2009 | 05:54 AM
jamon8's Avatar
Engine: 350 tpi
Re: 89,305,tpi dies
the ground is on the pass head
put a coat of die electric grease on the terminals that connect to the computer
Old Mar 5, 2009 | 10:03 AM
Nater36's Avatar
Re: 89,305,tpi dies
do you have a multimeter?
if you do just ohm test your injectors. Its quick and easy.
Old Mar 6, 2009 | 03:13 AM
jamon8's Avatar
Engine: 350 tpi
Re: 89,305,tpi dies
[QUOTE=Nater36;4068180]do you have a multimeter?
that should be minimium for posting in these forums
Old Mar 8, 2009 | 06:55 PM
89used2roc's Avatar
Re: 89,305,tpi dies
[quote=jamon8;4069345]
yea i tested the injectors they are fine along with 42psi on the fuel rail now i wondering if the egr valve would set a code 21
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
