Tpi ram air box for a tbi??
Old Mar 5, 2009 | 10:02 AM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
I was told that a tpi ram air box can be modified for a tbi, how is this done and has anyone here done it before??
Old Mar 5, 2009 | 10:08 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Tpi ram air box for a tbi??
on a camaro , easy job . on a bird IDK , but i'm sure somebody has done it . good luck .
Old Mar 5, 2009 | 10:18 AM
Stephen's Avatar
Car: 87 GTA
On 'birds, there's no way to fit the Camaro TPI air piece under a STOCK hood. Not enough room over the radiator wall. I tried....
Maybe with a cowl induction hood or a RA1 hood. But with a RA1 hood, you'd simply use that opening to get an even better ram air effect.
Old Mar 5, 2009 | 03:58 PM
Engine: V8 305
i don't have a stock hood, i have the RA II hood, whats the process?
Old Mar 5, 2009 | 04:05 PM
Stephen's Avatar
Car: 87 GTA
But it is flat in the middle, where the tubing would go to the throttle body. Which is why I said maybe with a RA1 & didn't mention the RA2 hood.
You'd hafta figure out how to mount the hood latch too (unless you have pins) Since the 'bird latch is held in place by that big flat metal plate, that would hafta be replaced with a Camaro piece.
Maybe you could swap the Camaro latch parts over as well, but you'd still have the hood clearance to deal with, over the radiator.
Old Mar 6, 2009 | 05:55 AM
Engine: V8 305
so in other words, sucks to be me,lol.
Old Mar 6, 2009 | 08:22 AM
Stephen's Avatar
Car: 87 GTA
Instead of using a Camaro piece, you could duct your cool air from the nostrils in your RA2 hood.
Old Mar 6, 2009 | 03:34 PM
Engine: V8 305
how would i do that?
Old Mar 6, 2009 | 03:44 PM
Stephen's Avatar
Car: 87 GTA
With the air filter box they specifically sell to do that, or make your own version of it.
Old Mar 6, 2009 | 03:51 PM
Engine: V8 305
who sells it? i can't find a tbi/carb box anywhere.
Old Mar 6, 2009 | 04:09 PM
Stephen's Avatar
Car: 87 GTA
Use this for the filter mount....(Hawks has it. I'm sure others have it too)
Duct it like this to the TBI.....
And use this.....
eBay example to the TBI/carb hat above I believe he bought his at Pep Boys, IIRC.
Piece of cake!
Old Oct 12, 2009 | 12:25 AM
Fender Engineer's Avatar
Car: 91 Camaro Convertible RS
Engine: Currently 5.0L
Axle/Gears: Borg Warner 3.27
I am planning on making a similar setup, but I have a few questions for you:
1. What size pipe did you use to run from the air box to the snorkel? (I.D.)
2. What kind of rubber connectors did use use to attach the two sections together?
3. Was there a noticeable difference in performance after the mod?
I have a 91 RS convertible that needs a breath of fresh air...if you know what I mean.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Sanjay
Aug 12, 2015 03:41 PM
bryan623
Aug 10, 2015 11:33 AM
