Difference in 081 heads and 187 heads
Old Mar 5, 2009 | 11:51 AM
wannaz's Avatar
Car: 90 iroc z
Engine: 350 needs work
Transmission: 700r4 needs work
Im looking at a 305 with the 187 heads on it. will these work with tuned port ?
Old Mar 5, 2009 | 11:57 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Difference in 081 heads and 187 heads
Physically, either heads will work. But you probably want to know which would be more ideal. Hard to tell, as few people are familiar with which 305 heads had which casting number, beyind the 416 heads. Pull an intake valve from each head. Then don't use the heads with the so-called Swirl Ports. If neither pair have these ports, then it won't matter which pair you use.
Old Mar 5, 2009 | 01:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
081 is TPI heads, 187 is the TBI (swirl port) heads.
Sorry, I misunderstood your question.
Yes, the 187s will work. No, they are not ideal or even that good.
Old Mar 9, 2009 | 11:17 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You cannot tell them apart by the valves, as both used 1.84"/1.50" valves. The only 305s to use the smaller 1.72" intake valves were the '76-'79 LG3.
evilstuie
Jan 9, 2020 08:29 PM
beastin91rs
Oct 9, 2015 07:38 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
bamaboy0323
Sep 3, 2015 06:07 AM
