new heads?
Old Mar 8, 2009 | 09:44 PM
jamesh23's Avatar
new heads?
im going to be replacing the fuel pump in my 91 z28 and it needs head gaskets, i was thinkin of just getttin new heads? how much are a pair of heads usually? and can i just put new heads on instead of changing the head gaskets? i wanna go performance anyway.
Old Mar 8, 2009 | 10:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The head gaskets are the seal between the block and head. If you replace the heads, you will be replacing the head gaskets. They aren't reusable.
There is no "usual" for the price of heads. Many, many choices out there. Figure on at least $700-$800 for new, though. Aftermarket performance heads typically start in the $1200/pair range.
Old Mar 8, 2009 | 10:36 PM
jamesh23's Avatar
Re: new heads?
there is a 4th gen camaro at the junkyard, leather seats, automatic, could i take the heads off of it maybe? or the seats at least for sure?
Old Mar 8, 2009 | 10:38 PM
jamesh23's Avatar
Re: new heads?
well is there an easier way to replace the head gaskets than actually replacing them? lol if not i guess ill do it but id rather not haha.
Old Mar 9, 2009 | 03:38 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: new heads?
If it really needs it, you will have to replace the head gaskets. There is no easy fix. It's really not that bad. i would much rather change both my head gaskets than replace my oil pan gasket. The haynes manual will show you how to do this. DO NOT TAKE ANY SHORTCUTS! Follow the instructions exactly! I would just take your heads to a cylinder head shop. Much cheaper than buying new. Now if money is no object, sure, buy a set of AFR aluminum heads like mine (2500.oo) but you said you were on a budget. Did you ever do the pressure checks I told you to do? You may not have blown gaskets.
Old Mar 9, 2009 | 03:39 AM
Re: new heads?
Oh, and 4th gen seats will bolt right in. if you see them and like them, get them. As far as engine parts, dont waste your time. Most of the parts are not interchangeable.
Old Mar 9, 2009 | 04:16 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: new heads?
Vortech heads/manifold are cheap and a decent upgrade.
Old Mar 9, 2009 | 09:44 AM
five7kid's Avatar
Re: new heads?
You can take the heads off, but they won't fit your engine.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
