Comp beehive spring installed height Qs
Old Mar 16, 2009 | 08:56 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
I am very excited that according to Carcraft i can drop in a set of comp 26918 or 26915 beehive springs into my vortec casting an instantly have 0.550" lift capabilities. I order to determine which springs best suit a GM lt4 HOT cam i need to know the height they will be installed at. I know that the stock vortec springs have a 1.700" installed height, but i am unsure if the behive retainers will change that (the 0.100 extra lift has to come from somewhere).
So i was wondering if anyone has used beehives in the past? Will the beehive specific retainers (comp 787) change the installed height realtive to the stock vortec retainers?
-Zander
Old Mar 16, 2009 | 09:15 PM
skinny z's Avatar
Re: Comp beehive spring installed height Qs
I have 26918 springs installed on my Vortecs.
Installed height; 1.820".
I've also had the heads machined for screw in studs and guide plates. The 1.6 Pro Magnum non guided rockers required the pushrods holes to be elongated as well.
Old Mar 16, 2009 | 09:26 PM
the zander's Avatar
thanks skinny, do you have stock length valves? If so thats good news, i won't have to hunt around for +0.100 valves.
-Z
Old Mar 17, 2009 | 07:53 AM
skinny z's Avatar
Original valves. Except for one which I bent during a missed shift. (7000+)
Old Mar 17, 2009 | 07:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You can also use Manley 22410-16 springs, 23652-16 retainers and get .550" lift with Vortec heads. They're not beehives but they might be less expensive. I used them just fine with my Corvette heads and LT4 hot cam.
Old Mar 22, 2009 | 02:38 AM
duderjay's Avatar
Car: 88 iroc z28
does that mean you do not have to do any machining? IE spring seat and valve guides?
Old Mar 22, 2009 | 08:18 AM
skinny z's Avatar
No machining required for springs seats or guides.
Old Mar 22, 2009 | 01:58 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Link to Car Craft please. I have installed '918s and ARP 134-7101 studs. I know theres an increase in available lift, but I had no idea it was that much. If thats the case, that opens all kinds of doors for cam selection.
Old Mar 22, 2009 | 03:41 PM
skinny z's Avatar
http://www.carcraft.com/techarticles...ade/index.html
Old Mar 26, 2009 | 03:39 PM
S105.7's Avatar
Engine: L98 & L03
Much appreciated.
Old Mar 26, 2009 | 04:17 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I got a package deal from comp themselves and run the 26918 beehives at 1.800 installed height and run an extreme fuel cam.....576./.571 lift and they work great...so those springs can handle over .550 lift....they are good to .600 lift according to comps web site!! http://www.compperformancegroupstore...&Category_Code=
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
