Synthetic Oil and Increased Engine Heat
Old Mar 17, 2009 | 05:31 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
I there any reason why switching to synthetic oil would cause an engine to run hotter? Recently, I switched from Quaker State 15W40 to Mobile 1 5W30 synthetic oil and the engine runs hotter. Could the weight change have caused the engine to run hotter? I suppose it is possible that something else is going on with the engine.
Old Mar 17, 2009 | 05:44 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Synthetic Oil and Increased Engine Heat
You went to a thinner oil?!?! For what, 5 horses?!?! Oil is the only coolant for the bottom end of the engine. And warmer weather will be here soon.
Old Mar 17, 2009 | 05:49 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
When I had a new engine installed 55,000 km ago my mechanic suggested using 15W40 oil which has been changed regularily at 5000km intervals. When I switched to synthetic I was advised to use what the manufacturer recommended which is 5W30.
Old Mar 17, 2009 | 06:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Most likely has nothing to do with the oil.
Old Apr 19, 2009 | 03:21 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
The over heating problem was finally diagnosed and solved. It of course had nothing to do with the engine oil, it just happened to occur at the same time. I guess that is what you call a co-incident.
Any how after checking everything I noticed the over fill tank was not rising and falling as the engine heated up. So after the engine cooled I removed coolant from the radiator to well below the core. Then the car ran cool. I concluded the radiator cap was defective. A new cap corrected the problem.
Old Apr 19, 2009 | 03:31 PM
five7kid's Avatar
I've heard of synthetic oil being blamed for flat tires.
Glad you found the problem.
Old Apr 19, 2009 | 06:21 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Im still a conventional guy when it comes to flat tappet motors.
And, I have grenaded a engine after a synthetic oil swap, but the 120degree
heat and ignorance had nothing to do with that one whatsoever.
Old Apr 19, 2009 | 08:55 PM
five7kid's Avatar
I hate to turn this into a "my dad's bigger than your dad" thread, but since you brought up flat tappets, I will respond.
"Conventional" oil does not protect flat tappets better than synthetic. In fact, it is worse. The issue revolves around ZDDP anti-wear additives - with the advent of the ILSAC GF-4 standard, the max allowed was reduced for the sake of emissions-control equipment (beyond 3rd gen, BTW). Since almost all new vehicles have roller lifters, that isn't a problem. But, for a flat tappet engine, the worst case scenario is a petroleum-based oil rated ILSAC GF-4. The answer is to use an oil that isn't ILSAC GF-4 rated; a simple choice is a diesel oil that is also rated for gasoline engines. As you might expect, a synthetic diesel oil rated CI-4+/SL is going to protect your lifters better than a CI-4+/SL petroleum-based oil - both will have the ZDDP anti-wear additives in sufficient quantity to protect the flat tappets, but the synthetic (especially Group 4) will always have the upper hand in this and overall lubrication protection.
I only went off-topic to address an off-topic post, so please, don't turn this into a synthetic vs. petroleum oil debate.
Old Apr 20, 2009 | 06:30 AM
TPI's Avatar
are you serious? the question was clearly resolved..
my humor was not meant to strike a debate or anything!
You could have supplied that morsel of information without
putting me in your cross hairs or ripping my post up.
Old Jul 20, 2021 | 01:33 PM
randyhummel's Avatar
Car: 1986 Iroc-z, 1968 Camaro RS-ss
Engine: 305, 396
Transmission: auto
what type of oil you running?
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
