Help please!!
Old Mar 19, 2009 | 04:09 PM
crivera108's Avatar
Help please!!
Okay so I pulled the starter from my 89' Iroc-Z and now I can't seem to get the new one into position to bolt back on. Can anyone please give me suggestions to help me with this. I could'nt beleive how quickly I removed the old one and how much trouble I am having tryin to put in the new starter. Thanks in advance for any help.
Old Mar 19, 2009 | 04:40 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Help please!!
I want to help, but I'm not really sure of why it's proving difficult. You just stick the back end up first, then once it's above the y-pipe, turn it 90 degrees and start the bolts.
Old Mar 19, 2009 | 04:57 PM
crivera108's Avatar
Re: Help please!!
I was trying to put it back in the same way it came out. If I remember correctly, I pulled the back end down and out first. So you're saying push the rear end of the starter (flat side) up inside first and then reposition till front lines up with mounting holes? I keep hitting the y-pipe and it won't let me turn the starter to get it in position.
Old Mar 19, 2009 | 05:02 PM
50bmgshooter's Avatar
Re: Help please!!
try putting it in with out the batt cable installed first
Old Mar 19, 2009 | 05:06 PM
Guest
Guest
Posts: n/a
Re: Help please!!
i just did this u have to put it in backwards then turn it around once in there. its very difficult but the only way without taking the exhaust off
Old Mar 20, 2009 | 07:50 AM
crivera108's Avatar
Re: Help please!!
Thanks guys, keep the help coming.
Old Mar 20, 2009 | 09:41 AM
Guest
Guest
Posts: n/a
Re: Help please!!
did u get it in there? its a pain aint it lol
Old Mar 20, 2009 | 10:21 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Help please!!
Gravity was helping you the first time. If it's comes to it, just loosen the Y pipe and pull it down a bit.
Old Mar 20, 2009 | 10:35 AM
Guest
Guest
Posts: n/a
Re: Help please!!
lol sometimes thats easier than said
Old Mar 22, 2009 | 12:42 AM
crivera108's Avatar
Re: Help please!!
AGREED!!! LOL
I'm going to try it tomorrow morning. Wish me luck you guys.
Old Mar 26, 2009 | 09:13 AM
crivera108's Avatar
Re: Help please!!
Thanks to everyone. I finally got it back in. no problem.
