March pulleys help plz
Old Mar 20, 2009 | 09:01 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
http://www.thunderracing.com/catalog...id=111&sid=343
I was wondering if I could just buy the 03-4000 --2 piece set. Would I need anything else? What is the difference between a 2 and 3 peice set?
03-4000 March Pulley Set, Performance Series 1988-1992 Camaro/Firebird 305/350, 2 piece Aluminum/Steel set (Gloss Black Powdercoat) $87.99 Buy Wish
03-4010 March Pulley Set, Performance Series 1988-1992 Camaro/Firebird 305/350, 3 piece aluminum set (polished & clear powdercoated) $197.47 Buy Wish
03-4410 March Power & Amp Series Pulley Set, 1988-1992 Camaro/Firebird 305/350, 3 piece aluminum set (polished & clear powdercoated) $197.47 Buy Wish
03-4415 March Power & Amp Series Pulley Set, 1985-1987 Camaro/Firebird 305/350, 2 piece steel set (Gloss Black Powdercoat) $98.29 Buy Wish
Old Mar 20, 2009 | 09:15 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: March pulleys help plz
Two piece is the crank and alternator. A 3 piece adds a water pump. Although, using anything besides the crank is self defeating as the ratio between the accessories is then maintained. The idea is to under drive everything to keep the energy necessary to spin the stuff down, (a reduction in parasitic loss). I run just the crank pulley on my 'vert and did the same on my old 'formy. Never had cooling problems. The worst that happens is when running at night or with the A/C on, at stoplights, I have to pop it in to neutral and bring the idle up a bit due to the voltage drop.
Old Mar 20, 2009 | 09:22 PM
Car: ws6
Engine: ls1
Transmission: m6
Ok man thanks a bunch.
Old Mar 20, 2009 | 11:56 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
if you get the power and amp series, it eliminates that problem by using a smaller alternator pulley and only underdriving the alternator by 2% rather than 20% like the other pully's.
Old Mar 21, 2009 | 12:31 AM
Camaro383ci's Avatar
Car: 84 Berlinetta
Engine: Bottle Fed 383ci
Transmission: Stage2 T56 Ram powergrip HD clutch
Axle/Gears: Ford 9" Detroit tru track 4.11 gear
you also need to bee careful not to over rpm the alternator. I think 19,000 or 20,000 rpm is max u can spin a alternator. heres a formula to make sure your in the clear.
Speed of drive pulley X Diameter of drive pulley
____________________________________________
Diameter of driven pulley
Old Mar 21, 2009 | 10:56 PM
watajob's Avatar
Car: 92 T/A 'vert
You're underdriving the accessories. They'll never spin as fast as a stock crank pulley so it shouldn't be a problem.
Old Mar 21, 2009 | 11:34 PM
Car: 84 Berlinetta
Yeah i'm an idiot. (sorry) I just went through an over heating problem with my march performance setup. so i switch pulleys to high flow water and still had a problem. So i called them up and they got any pulley u need so i played with pulley combos. In the end it wasn't even the pulleys. I was just thinking of what you where saying and jumped the gun.
Old Mar 21, 2009 | 11:42 PM
Car: ws6
Engine: ls1
Transmission: m6
Do you think id have a problem with the 2-piece. Is the amp series a better investment?
Thirdgen89GTA
Nov 26, 2015 11:04 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
