Wrong valve cover gaskets.
Old Mar 21, 2009 | 11:51 PM
Seanmz28's Avatar
Hey again everyone, I have a quick question about valve cover gaskets. My brother who started this prject bought the wrong gasket kit for the heads he had purchased, so now I have make up for his mistakes.
My question is: If I have the center bolt style vortec valve covers, and I have a gasket for the type of valve cover that bolts onto the side of the head, can I just razor blade the extra material off of the gasket and use it, or would the engine leak oil from where I jerry rigged it? Thanks for the help.
Old Mar 22, 2009 | 01:19 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Wrong valve cover gaskets.
you may be able to do it that way, but i would expect leaks right away.
if you still have the old center bolt VC gaskets, many times you can reuse them without problems if they are in good condition.
Old Mar 22, 2009 | 02:11 AM
Seanmz28's Avatar
Unfortunately, I bought the car as just a rolling chassis, it had no engine or tranny, so I have no old gaskets to work with. I guess I am gonna have to shell out the whole 15 bucks for new ones.
Old Mar 23, 2009 | 12:35 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Yeah. Unfortunately the older style valve cover gaskets are different than what you need. Shaving the material won't help you a bit. Just be happy these gaskets are cheaper than some of the ones out there.
Old Mar 23, 2009 | 12:46 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Any centerbolt gaskets I've seen are rubber, where the perimeter bolt gaskets seem to be cork. Just pick up the proper set, it's not worth skimping on something like this.
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 8, 2015 01:18 AM
