Annoying clicking noise
Old Mar 23, 2009 | 11:16 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
Every time i try to start the car it won't crank. instead it clicks as if its hesitating or something. it'll repeat this and i have to play with the ignition turning it off and on until finally the engine cranks over. I've been told a lot of different things could be wrong. Battery, starter, possible chip in key, etc. Bottom line, i'm tired of it. Before going out to spend money i'd like to see what yall think is wrong and if yall have had the same problem. If so what could i do to make it stop?
Old Mar 24, 2009 | 07:00 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Annoying clicking noise
weak battery , or bad/corroded battery cables .
Old Mar 24, 2009 | 07:03 AM
50bmgshooter's Avatar
sounds like a bad ground
Old Mar 24, 2009 | 07:43 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Sounds like all the right answers but you might want to include a bad starter. If you have VATS (Vehicle Antitheft system), You system won't click it just won't start and on some a security light will come on.
1. Load Test your battery, Don't just put a Multimeter on it. Should have 12+ volts and roughly no less than 650 CCA's after test
2. Check your + Positive Battery wire on starter and battery. Look for tight connections and no corrosion.
3. Check your - Negative Battery wire to Groud Wire(Same as NO# 2)
4. If all the above are good, with your Key in the off position.. put a jumper wire on your starter, jumping the purple wire on the starter with the Main + Battery wire, Hint!!!(these are the only 2 wires on your starter) Do not short them out with a ground on yoru vehicle unless you like sparks!!!! Your starter should crank over. It it just clicks after all conditions above are met, Change your bendix or starter itself. Ensure your engine turns over. If your engine is setup, no matter how good your starter is, "IT WON"T START"
Old Mar 24, 2009 | 08:13 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
there are a bunch of things it can be.
one is the started solenoid
or the starter can have a bad connection inside of the plastic box.
if the security light is on its vats.
check the neutral safety switch.
you are just going to have to follow the current. pain as it is, but it happens.
then there is one of my favorites and a real fluke.
when the people put in the original replacement battery they did not have a long enough ground cable so they used a red hot cable. so anyting anyone looked to charge the battery they put the red to red and it drained the battery. unless you had the battery out you did not see the + on what looked like the ground size, but what was actually the hot side.
Old Mar 24, 2009 | 08:44 AM
Sully89Firebird's Avatar
Car: 1989 Firebird Formula
Engine: Stock 305 TPI
Transmission: 700R-4 w/ Shiftkit
Axle/Gears: Stock 2.73
happened to me a few weeks back. turns out it was corroded battery terminals
Old Mar 24, 2009 | 09:06 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
Old Mar 24, 2009 | 09:36 AM
ibmtech's Avatar
Car: 1987 IROC-Z
We have given him the plethora of knowledge to help fix it. Now he has to apply it. Putting a little grease or terminal protector spray on the battery terminals saves alot of grief sometimes. This sounds like a real simple problem that everyone has overlooked many times and then bites them in the a$$ once they figure it out.
RS Reaper
Oct 17, 2018 07:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Linson
Oct 1, 2015 09:50 PM
sjorgens
Oct 1, 2015 07:54 PM
