Help me identify these two pieces?
Old Mar 26, 2009 | 04:52 PM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Hello all,
Im restoring my 86 z28. I already have pulled my old engine out, and the new engine im going to be installing is going to be free from emission devices. I was wondering what exactly these two things do, and if I can removes them since I will not be worring about emissions anymore?
-Andrew
Old Mar 26, 2009 | 04:59 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Help me identify these two pieces?
the black round can is you vapor canister you can get rid of that and the small round one is for cruise control
Old Mar 26, 2009 | 05:00 PM
wshbrn91's Avatar
Perfect answer. Exactly what i was looking for. Thank you very much!
-Andrew
Old Mar 26, 2009 | 07:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The vapor canister is something you can remove if you want to make your life harder. If you like keeping things simple and better, you'll keep it.
Old Mar 26, 2009 | 07:49 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Weird...mine doesnt have the vapor canister....whats it do?
Old Mar 26, 2009 | 11:15 PM
Pocket's Avatar
Car: 91 Trans Am
Stores unburnt fuel and sends it back to the gas tank
Removal you can expect about 1/2 mpg drop and will have to install a vented gas cap
Old Mar 26, 2009 | 11:25 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
is that something that is on tbi as well at tpi?
Old Mar 27, 2009 | 04:22 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Not if you run the vent line inside the fender.
Old Mar 27, 2009 | 06:48 AM
wshbrn91's Avatar
I hate conflicting answers... I knew it was to good to be true hahaha. Alright then, well I am going to have no idea how to connect this when my new engine is so im sure you guys will be hearing back from me soon enough.
Old Mar 27, 2009 | 03:24 PM
Pocket's Avatar
Car: 91 Trans Am
A $3 gascap is cheaper/easier than re-doing a fuel line to go behind the fender and buying the correct sized weather proof vent
Old Mar 28, 2009 | 09:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
All it is is extending a rubber "vacuum" line through one of the holes in the inner fender. It will vent the gas fumes outside of the engine bay.
Cheaper than a 3 dollar gas cap if you have a nipple and vacuum line laying around.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
LC2 TECH
Oct 13, 2015 11:53 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
RS Reaper
Sep 27, 2015 07:04 PM
