The build begins!
Old Mar 27, 2009 | 01:52 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
The build begins!
Well like the title say's im finaly building a new motor and man have i been waiting lol. Im taking the block moday to the machine shop to get checked over before i order all my parts but what i have is a 3932388 virgin bore 69 2 bolt block. Plans for the block at the shop is clean magnafulx bore/hone 0 deck cleranced for stroker crank pistons pressed on rods ect ect you get the idea. Anyway i just ordered scat 9000 lightweight stroker crank and scat press fit 5.7 forged i beam conecting rods for stroker setup. Slugs will be forged wiseco 5cc flattops for stroker. Im keeping the block a 2bolt but studding the mains. i havent ordered the pistons yet just in case for some reason needs more than a .030 overbore. with my brodix ik200 heads 70cc and a stock headgasket i should have around 10.3cr so it will be pumpgas friendly which is my goal since i do plan to drive the car regularly (couple times a week maybe). custom ******* performance stall will be built for my setup once everything is done to help get me going. ill keep the updates as i get them and ill post plenty of pictures. I will also be assembling the engine myself so that should cut down on the costs some. total build should be about $3300-3500 thats everything from heads to oilpan.
Old Apr 2, 2009 | 03:57 AM
Screamin86's Avatar
Re: The build begins!
hehe look what the man in the brown van dropped off yesterday. ill get some more pics later and out of the boxes but here are some teasers!
Old Apr 7, 2009 | 03:54 AM
Screamin86's Avatar
some more pics. called the shop today and he hasnt had a chance to check the block over since there busy with all kinds of motors for the local racers. plans to get to it tomarrow.
ZZ3Astro
Aug 13, 2019 12:57 AM
Veaceonee
Sep 29, 2016 08:15 PM
PurelyPMD
May 5, 2016 04:57 PM
tyeo098
Nov 30, 2015 06:27 PM
okfoz
Sep 22, 2015 03:37 PM
