Problems changing the fuel filter
Old Mar 27, 2009 | 12:27 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I've done this in the past on my car and did not have this happen. I Unpluged the fuel Pump relay and started the car to depressurize the lines. I put the rear up on jackstands and put a drain pan under the filter. Broke the lines lose and started unscrewing it. Gas started flowing, wich I expected. But it kept going, I drained 5 gal. out before the flow stoped. I am assuming that a sophen action got started. Is this normal?
Old Mar 27, 2009 | 12:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Problems changing the fuel filter
Yep, that's pretty normal. If your line is below the tank (most all are...)
Blow on the line to blow the air back into the tank, or just work fast... Or just let it all drain, then throw it back in the tank later.
Old Mar 27, 2009 | 12:54 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Humm ok, I tried the work fast method last night and now have chemical burn on my arm (I think the sta-bil I had in it) but I wasn't prepared with enough clean containers and ended up with contaminated fuel I now need to get rid of. Oh well lesson learned, I guess I got lucky the last time I changed it.
Thanks for the info.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
