305 to 350
Old Mar 28, 2009 | 09:54 AM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
305 to 350
is it possible to take my heads and tpi off of my 305 and put them on a 350 block?? what about a 383?? i really need some advice/ input because i found a 350 block reasonably priced but the guy wants to sell it today.. so the sooner i can get some thoughts on the subject the better.
thanks!
Old Mar 28, 2009 | 12:13 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: 305 to 350
Physically, yes they will fit. You will need to be careful of your compression ratio because the 305 heads have a smaller combustion chamber than what the 350 would have come with so you may run into issues with too high of a CR. The other issue I can see would be with the computer. At the very least, you should get it retuned to work with the 350, especially if you are using a different cam. Some cams are not compatible with the ECMs in our cars. It can be made to work, many people have done it. In fact, I'm using 305 heads on my 350 block, but I'm using a carb instead of TPI.
Old Mar 28, 2009 | 03:43 PM
Re: 305 to 350
what if i purchased a set of 194 heads also? would the tpi still be cool? would i need to change injectors and ecm??
Old Mar 28, 2009 | 04:42 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: 305 to 350
ECM and injectors have nothing to do with the heads, and everything to do with filling the now larger cylinders with the proper air/fuel mix. The 350 will probably run ok without new injectors or ECM, but it will be underpowered. Even worse than your current 305.
I'm not sure which heads you're referring to. Better heads will almost always help power levels, especially over stock heads. But if your going to be using a computer-controlled FI setup for induction, you still have to tune it for the best results.
Your best bet would be to upgrade your injectors and install a 350 ECM. You may be able to just swap chips since yours is a 305 TPI, but that is something you would have to ask on the PROM/Tuning board to get an accurate answer on.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
