Gettin my baby up for spring.
Old Mar 30, 2009 | 09:43 PM
Derrack's Avatar
Car: 1985 Camaro Z28
Engine: 305, 4bbl looks stock
Transmission: T5, looking to upgrade
so last year my car started running bad at a gas station. when i popped the hood i noticed the barometric pressure sensor was dangling on the header. twas melted. so i unplugged it and it ran better but not how it was. cant seem to find a diagram for the location it bolted to or where the vacuum hose is that attached to it. got another on the way looking for some help finding a diagram or maybe a few pictures from your cars if you have an 85 camaro with a quadrajet four barrel carb.
Old Mar 30, 2009 | 10:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's bolted to the cowl up by the AC/heater box. In the picture, if you look between the dipsticks, you can see the blue connector for the BPS.
https://www.thirdgen.org/forums/atta...aro-engine.jpg
Old Mar 30, 2009 | 10:42 PM
Derrack's Avatar
Re: Gettin my baby up for spring.
sweet and i can see the vacuum line kinda. ill root around to try to spot it. thanks alot.
Old Mar 30, 2009 | 11:08 PM
five7kid's Avatar
There's no vacuum line on the barometric pressure sensor. It looks like a vacuum nipple, but it's supposed to have a foam "filter" over the nipple (mine has never had the foam on it since I've had the car).
Old Mar 31, 2009 | 01:15 AM
Derrack's Avatar
bahaha, if i logged in the hours i spent looking for one in the car and following vacuum diagrams i could have prepped and painted the car. thanks a bunch bud.
Old Mar 31, 2009 | 01:29 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
isnt the barometric pressure sensor the same thing as the MAP sensor. shouldnt the map sensor have vaccum attached. it does on my L03 tbi 305, or is not supposed to have vaccum running to it.
Old Mar 31, 2009 | 10:31 AM
five7kid's Avatar
They look like the same thing except for the foam filter on the BPS. But, your car should have both the BPS and MAP.
ZZ3Astro
Aug 13, 2019 12:57 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
