intermediate shaft question (I DID A SEARCH TO NO AVAIL) LAST RESORT PLEASE HELP ME
Old Apr 2, 2009 | 02:58 AM
ILUVMY89's Avatar
okay so gm doesn't make them any more so i cant get one new from the dealership my old looks all tore up but most important of all the new steering column same year ect ect wont fit inside (slide in ) so i can bolt it down i tried a screw dirve in the hole but broke the screwdriver anymore ideas of how to widen the hole???? any help is greatly appreciated
Old Apr 2, 2009 | 12:51 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: intermediate shaft question (I DID A SEARCH TO NO AVAIL) LAST RESORT PLEASE HELP
I went through this a few weeks ago when I changed mine (for a good used one). The problem is that the bolt crushes the opening. I ended-up using a die grinder to open the hole enough to get it in.
Old Apr 2, 2009 | 01:59 PM
ILUVMY89's Avatar
how deep did you cut into it you would think that would be really dangerous
Old Apr 2, 2009 | 02:03 PM
jv9999's Avatar
Engine: 5.7L/350
It was only the first 1/4" or so and around the bolt hole. I thought there was still lots of metal left, but you be the judge.
Old Apr 2, 2009 | 02:32 PM
ILUVMY89's Avatar
around the bolt hole????? so you just cut it up to the hole??? or around the hole
Old Apr 2, 2009 | 02:40 PM
jv9999's Avatar
Engine: 5.7L/350
I think you might misunderstand. I used a die grinder with a cone shaped grinding wheel on it. I took metal from the inside of the collar. I didn't cut any part of it off. Much like you would do with a file if you had a lot of time and patience.
Old Apr 2, 2009 | 02:59 PM
ILUVMY89's Avatar
i gotcha now all you said was a die grinder i thought you cut a slit through both sides up to the hole which would work too but were could i get one of those cones
Old Apr 2, 2009 | 03:37 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
This? http://cgi.ebay.com/ebaymotors/Camar...Q5fAccessories
Old Apr 2, 2009 | 04:53 PM
ILUVMY89's Avatar
yes thats it but idk if im gonna buy it i might just try wat the other guy did unless that doesnt work then i will
Old Apr 2, 2009 | 06:01 PM
jv9999's Avatar
Engine: 5.7L/350
Sears has them in a kit: http://www.sears.com/shc/s/p_10153_1...otary+Grinding
(In the stores as well as online)
Old Apr 5, 2009 | 08:00 PM
ILUVMY89's Avatar
i just bored it out woth with the grindin cone got it at home depot for 2 bucks worked perfect who knew it would be that easy
Old Apr 5, 2009 | 08:19 PM
jv9999's Avatar
Engine: 5.7L/350
Glad to hear it worked out for you.
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
jharrison5
Aug 19, 2015 05:53 PM
formula_novice
Aug 18, 2015 08:48 PM
redmaroz
Aug 16, 2015 11:40 PM
MENINBLK
Aug 5, 2015 11:58 PM
