Will my fan work if I do this?
Old Apr 6, 2009 | 07:53 PM
87v6Bird's Avatar
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
I have an 87 Firebird with dummy lights and I want to install a water temperature gauge. The thing is if I remove the stock temp sending unit to install the other sender my fan will no longer work. Right? Is there any easy way to get around this problem? By the way the gauge is mechanical.
Old Apr 6, 2009 | 08:24 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Will my fan work if I do this?
i installed an aux. temp. gauge in my previous 3rd gen. . i used the block drain hole/plug to install mine . i used the drivers side since it involved less routing of the temp. lead . on the lower part of the block , fwd. of the oil filter and 2-3 " above lip of oil pan . you will see a small pipe plug , remove plug install sensor . if if your block is like mine was there will be a build-up of rust scale & crud . poke hole with a screwdriver to clear scale . don't try it hot & be prepared for water to come out when you clear hole . worked for me . good luck .
Old Apr 6, 2009 | 09:11 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The sender for the temperature gauge/light is separate from the sender for the radiator fan, so you should be okay.. The fan switch is on the passenger side head, close to the back.
Old Apr 6, 2009 | 09:25 PM
87v6Bird's Avatar
Engine: 406, LB9
Ok thanks. Both ideas sound good I didn't realize the senders were separate.
Old Apr 10, 2009 | 09:27 AM
87v6Bird's Avatar
Engine: 406, LB9
I haven't gotten under my car and looked around yet, but is this for a V8? Would it be in the same place for my V6? Hopefully I'll get everything put in tomorrow.
Old Apr 10, 2009 | 09:40 AM
87v6Bird's Avatar
Engine: 406, LB9
I found this thread after some more searching I think it answers my question pretty well.
https://www.thirdgen.org/forums/v6/4...ensors-v6.html
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
