location of all the sensors on the V6 block
Old Feb 22, 2008 | 08:22 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
can sombody tell me the locationds of the sensors on a 91 3.1 V6 camaro.
I'm specificly interested in the Knock sensor,and temp sender.
9 need exact locations inside block, outside block, obve somethnig , underneath something.
everything.
Old Feb 22, 2008 | 12:54 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: location of all the sensors on the V6 block
Here's the list.
Knock sensor: Passenger's side of block, underneath the exhaust manifold, next to the starter.
Temp sensor (coolant): Front top of engine, underneath the throttle body. Has black and yellow(?) wires running to it.
Temp sensor (intake air): Screwed to a nut welded to the side of the air cleaner can. Probably on the front side of the can, yellow and purple wires.
MAP sensor: (I don't have one, not really sure, if wrong, someone correct me): Driver's side of engine bay near brake booster. Has a green three-wire plug and a vacuum line running to it.
O2 sensor: Underneath the car, in the engine crossover pipe, near the passenger's side lower A arm. Single black wire running to it, 7/8", will probably need heat to replace.
Throttle position sensor: Passenger's side of the throttle body, has 3 wires running to it, and is non-adjustable for the most part.
Idle air control motor: Above the TPS, has a four-wire connector, 2 blue and 2 green.
Oil pressure sending unit (also sensor): Near the oil filter on the driver's side, has 3 wires running to it. White, orange, and black.
Any others, I've forgotten, feel free to ask. Also, your ECM (engine computer) is up under the dash on the passenger's side of the car. You need to remove both lower panels to get at it. (Just in case you needed to know)
:edit: Just noticed you're across the pond. (Swap the driver's side location for the TPS and the knock sensor).
Old Feb 22, 2008 | 02:21 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
still need th temp sender for the gauge.
Old Feb 22, 2008 | 02:55 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Im not sure of the wire colors, but the MAP sensor is on the pass. side bolted to the lip on the firewall. Almost right above the ign coil.
There is another coolent temp sensor in the front of the driver side head.
Old Feb 22, 2008 | 03:08 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
I think You both mean the same temp sensor.
I'm looking for a 1 wire ( green ) sender unit that goes to the gauges.
( also, does the knock sensor bolt into a waterplug ( I mean, if i get it out, will I get a shower of water over me ? same goes for the temp sender to the gauge.
Old Feb 22, 2008 | 05:11 PM
grimmcs's Avatar
Car: 91 Camaro
The knock sensor does act like a coolent drain plug for the pass side of the engine.
Old Feb 22, 2008 | 05:42 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
That one is under the TB I believe on the intake manifold and the one that kicks the fan on is on the back of the passenger head.
Old Feb 22, 2008 | 11:20 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You didn't say anything about the temp sender.
But, anyways, the sender is the single wire unit he has in the second pic above, the one with the funky looking connector and the green wire running to it. Your 3.1 does NOT have the fan switch in this same position on the pass side head, as it completely relies on the ECM and the CTS for switching the fan relay on and off.
Old Apr 7, 2008 | 06:33 PM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
Ok so where do i hook up an external aftermarket temperature gauge? I am going batty with not understanding where...
Old Apr 8, 2008 | 12:06 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
or you put the new one in place of the old 1.
or you drill a hole in your block. or in another place where there is running hot water from your block. ( do not place it behind your thermostat since it wont measure the water then till the thermostat opens)
Old Jun 11, 2008 | 12:04 AM
ScottR91RS's Avatar
My 91rs 3.1 temp sensor is front driver's side right behind the a/c punp it is brass with a flat like top with a slide on kinda 90 degree connector. This runs the gauge only nothing else that I know of.
Old Jun 11, 2008 | 03:19 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
yups, the small 1 near the collector only runs the gauge.
already found that 1. changed he senderwith the new 1 rom nordskog together with giving it an all new wire to my dash.
I can tell you, this thing is accurate
with my 180 thermostat. on the freeway, my temp is between 179 and 181 degrees.
thats less then a 1% error read.
Old Oct 5, 2008 | 11:55 PM
chattersonm's Avatar
Car: 1986 camaro sport coupe
Engine: 2.8 v6 MPFI
Transmission: LB8
Axle/Gears: 2HH 3.42:1
is this the same for the 2.8 v6's to? cause i think i know where my coolent temp sensor is...but how to i get to it to change it?
Old Oct 6, 2008 | 08:21 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You can either do it the hard way by removing the upper half of the plenum or get yourself a flex-joint for a 3/8" ratchet and use a 5/8" (please tell me I'm right) deep socket to get to it from the driver's side of the engine.
And for those newbies out there, the 2.8 and the 3.1 are the same engine with the exception of the computer and fuel injection system, crankshaft, and pistons.
Old Apr 30, 2009 | 09:10 AM
milleym's Avatar
Car: 1986 Firebird S/E
Engine: 2.8L 173cid V6 MFI
Hi -
I'm in the middle of changing a head gasket, and I found this sensor (sender?) was completely broken--literlly, the top half of the sensor was completely missing, and so I don't know what the lead coming off of it looked like, or where it ran to. I don't even know if I need the part called Coolant Temp Sensor or Coolant Temp Sender---they are both the same size, but the connection is different. (BTW, the previous owner has hardwired th fan to run all thetime, probably because he was too lazy to replace the sensor.) See pics here: https://www.thirdgen.org/forums/tech...me-sensor.html
Can someone please post a photo of what this (the temp sensor/sender connection on the back of the passenger's side head) is supposed to look like?
Thanks,
-Mark
Old Apr 30, 2009 | 07:31 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You're looking for the 2-wire sensor in the pics above (next to the thermostat housing, top pic). The connector looks almost the same as does the connector for the air temp sensor in your air cleaner can, except it's black instead of gray.
:edit: It may not be that your fan has been hardwired to run. Your ECM may just be running the fan because it doesn't know how hot the engine is. Also, expect cruddy mileage and nearly black exhaust, as the ECM will be adding fuel because it thinks the engine temp is below zero (IIRC, anyways). I worked on a 95 Grand Prix that had this problem.
Old Feb 15, 2011 | 06:24 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
hey guys, i ran into a problem with this, i got the old unit out but now i cant get the new sensor into the hole?, it just sits and spins on me, any help?
Old Feb 16, 2011 | 04:54 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You'll want to pull the upper plenum off and get it started by hand... DO NOT use a wrench to get it started as you could strip out the threads in the intake by cross-threading the sensor with the intake threads (if you haven't cross-threaded it already).
BTW, my mistake... It's a 3/4" wrench or socket you use on the CTS.
Old Feb 16, 2011 | 05:44 PM
Engine: L31 350
i have it off, i cant get the new one started, the old one goes in jsut fine but that new one just wont budge
Old Feb 16, 2011 | 08:14 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Check the 2 sensors side by side, comparing the threads. And not just 2 threads, check the whole length from the thermistor end (in the engine) to the part the wrench sits on. If there's nothing in the way and it's not going in, you probably have either bad threads in the intake or the wrong replacement sensor, or some guy at the machine shop that made the sensor body screwed up the threads good.
Old Feb 16, 2011 | 08:30 PM
Engine: L31 350
checked the threads they are right, the replacemnt is alittle longer and alittle wider, i just dont understand, the original goes in fine but the new one wont go in.....
Old Feb 16, 2011 | 08:42 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If the new sensor is wider (at the threads), that's why it's not going in. It's not going to fit in the hole unless you rethread the hole larger. Take it back, take the old one in, and tell the guy you need one just like it. Don't rethread the hole larger as you may need another replacement sometime that is the right size and it then won't fit.
Old Feb 16, 2011 | 08:47 PM
Engine: L31 350
will zone take it back? iv already got tape on the threads so it didnt lock to the metal, i havent plugged it in yet
Old Feb 16, 2011 | 08:56 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Another thing: Get in the habit of NOT using thread tape on the coolant sensors, with the exception of the knock sensor (that you had in the 91 by the starter). The gauge sender, in particular, grounds through the threads into the cylinder head, and the tape can mess up the resistance readings (you can possibly get away from it in the intake sensors but I wouldn't advise doing so on a regular basis to avoid a habit in case you get stuck working on a late-model car that has the all-in-one gauge and ECM sender). Get a wire brush and clean the tape off (preferably brass). Just tell them you bought the wrong part (or they made a mistake and gave you the wrong part in the right box... Had that happen at NAPA a few times).
Old Feb 16, 2011 | 08:58 PM
Engine: L31 350
ok, i have the recipet and everything but my step dad did the tape when he was lookin at it today when i was at school, i didnt have to take the plenum off to get the original out...
Old Feb 16, 2011 | 09:00 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Or, maybe if you get lucky enough, you can find the end of the tape and unwind it...
Old Feb 16, 2011 | 09:12 PM
Engine: L31 350
yeah..
Old Dec 22, 2011 | 05:25 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I bought a temp sensor the other day and it already had red tape on it. Is that normal. It is like half way up the threads. When I read this and you mentioned not to use tape I thought it was odd. Got it at The new O'reilly's they took over checkers.
Old Dec 22, 2011 | 07:12 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If it's the 2-wire unit, it's fine... Don't use tape on the single wire unit.
Old Jun 2, 2014 | 12:18 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
I'm reviving this old thread to present the temp gage and drivability problem I'm having.
Here are the facts:
  • 1988 Camaro with 2.8 V6 and manual transmission
  • Temp gage readings are erratic
  • Start motor and let run at idle until fan kicks on (about 15 minutes)
  • Temp gage comes up only slightly (still reads at nearly the bottom of range)
  • Drive for 10 minutes and motor runs strong - gage does not come up to middle of the range like it should if operating normally
  • Gage needle then drops to almost absolute bottom of range
  • Deliberate, aggressive hard-acceleration --- and then as motor reaches peak of powerband (yeah, 2.8 stock motor "powerband" ha-hah) the motor stumbles hard
  • stumble feels like fuel to all cylinders has been momentarily shut off, then motor "comes back" - severe "whiplash" type driving sensation as motor rapidly dies-and-recovers
  • This condition will persist until temp gage "recovers" and starts showing believable readings
  • When gage runs in the mid-range to just slightly above mid-point, this stumbling problem never happens, and motor runs strong
  • Problem only occurs when temp gage is reading at implausibly-low reading
Question:
Could the drivability issue be the temp sensor (or a bad connection at the temp sensor) sending bad info to the ECM, and then the ECM causing the fuel delivery system to provide incorrect fuel/air ratio such that this stumbling would occur?
I also sometimes get the stumbling very soon after the motor has "warmed up" when I'm just driving the car gently at light throttle.
The thing that keeps jumping out at me is that the stumbling problem never happens unless the temp gage is just slightly above the bottom of its display range. The maddening thing about it is that the gage can drop down into that low range when there is no possible way that the actual temp could the same as what the gage is showing.
Advice?
Old Jun 2, 2014 | 07:36 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Here are the facts:
Question:
Advice?
My guess? Air bubble in the system. Keep in mind you're dealing with 2 temperature sensing units. One for the gauge in the cylinder head and the other in the intake manifold. It's highly doubtful both of them are failing in the exact same manner at the exact same time. There has to be another issue in the system. Take the 2-wire sensor out. If coolant doesn't come out of the hole, you have an air bubble. Any air pocket in the system can cause the readings to be abnormally low, and lower readings from the actual ECM sensor can throw the system to the RICH side.
Old Jun 3, 2014 | 07:55 AM
W.E.G.'s Avatar
Engine: V6 2.8
Thanks for the reply!
I hadn't considered the air-bubble-in-coolant hypothesis.
Which of the two gages feeds data to the ECM?
Old Jun 3, 2014 | 08:10 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
No gauge feeds information to the ECM.
Old Jun 4, 2014 | 09:33 PM
W.E.G.'s Avatar
Engine: V6 2.8
OK.
I guess I'm confused that there would be two sending units if the only thing that is getting the info is the dash gage?
Where does the second sending unit send its info?
Old Jun 4, 2014 | 11:29 PM
OK.
Well, that's a totally different question.
There is a sending unit that connects to the ECM.
Old Jun 6, 2014 | 08:27 AM
W.E.G.'s Avatar
Engine: V6 2.8
Sorry for the imprecise language in the earlier post.
Any info on the location of the sending unit that feeds the ECM?
Old Jun 26, 2018 | 11:06 PM
W.E.G.'s Avatar
Engine: V6 2.8
Since I work at such a blistering pace, I seem to find it necessary to revive this thread every three or four years.
I swapped gauge-clusters on my V6 car today. Replaced the V6 cluster with a V8 cluster. Temp gauge needle was beyond buried. But, instead of immediately examining the needle closer, I pulled up this old thread, and I poked around under the hood until I found the green wire mentioned above. Single green wire. Connects to a spade-type connector on a screw-in sending-unit on the front, driver-side of the motor. Mine had no fancy cover on the connector. Just a bare spade-connector that looked to be intact. Connects to a sending unit that looks like this:
Instead of molesting the green wire, I pulled the clear bezel on the gauge cluster and freed the needle on the dash gauge. I'll report back in three or four years.
No seriously, here's the link to the thread that follows-on to my temperature gauge adventures:
https://www.thirdgen.org/forums/elec...luster-v6.html
I'm still a little confused about the temperatures that get reported to the ECM.
I'm getting my feet wet finally with TunerPro.
Not sure why I've got two coolant temperatures (different readings naturally) reporting to the ECM.
Old Jun 27, 2018 | 10:48 PM
Looks like who ever wrote that ADX has both Fahrenheit and Celcius.
Jorlain
Oct 8, 2015 01:57 AM
dusterbd
Sep 29, 2015 08:40 AM
Night rider327
Sep 16, 2015 02:20 AM
Nick McCardle
Sep 10, 2015 08:36 PM
